DWeeB
I installed some comp rated 1/2 shafts only but I'm still running the stock gearing. I'm sure they won't last long if I drive it hard, but it will have to do until I can afford the time and money required to do the shortened RX-7 deal. Plus I found it's not that stable at highway speed anyways, seems that it wants to lift if you punch it while going over 60. I'll need to lower the front-end, do some suspension upgrades and maybe an aero package. But it's a blast to drive!!!!!!!!!!!Branson said:remind me, are you running the original sprite rear or did you go with an rx7 rear?
Hi Guest!
