TR2/3/3A Right Front Suspension Damage Repair?
Well, after a delay working on the TR3 for a number of personal reasons, I finally found a frame guy that was willing to schedule the work (as opposed to "check back with me in a month or so"). I picked up the straightened frame earlier this week and he confirmed the shock tower was twisted and pushed in along with the frame. He was able to pull everything back into proper position (within 1/16" he says).
Yesterday I spent 3 hours removing the damaged lower fulcrum pin. I opted to drill the sucker out. After cutting the outboard brackets off, I took a sawzall to shorten the stubs to about 1/4" from the shock tower bracket. A little dykem and a center square allowed me to center punch the center on each end. On the forward part, space was VERY limited so I stubbed a 1/8" bit to 1 1/4" long and used an angle drill to place the pilot hole. I used a conventional 1/8" jobber bit on the other end and then switched to a 6" jobber bit to go all the way through. As you can see from the picture, I was close but not centered. The next pass was with a 1/4" bit that I biased to one side to hit closer to center on the front end. As you can see, it seemed to work. From there on I just stepped up with drill bits until I got to the final 7/8" diameter. I did need to do a little work with grinding burr to clean things up but I turned out fairly well. I didn't have a 3/8" chuck in my corded drill so I had to use my cordless and it really pushed the Porter Cable cordless to the limit. I had to stop a couple of times for the drill to cool when spinning the larger bits when the windings started to smoke. I've attached pictures so you can follow the sequence.
Next I'll be setting the frame up on jacks to check frame reference positions, making a jig to position the new pin parallel to the frame center line, and then welding the thing in.
Thanks for everyone's guidance!
Ron
Shortening lower pivotCutting pivot bracket from frameIMG_9106.jpgStubbing front pivotcenter markingclose but no cigarrear pivot holefront pivot hole after biasing while drillinggradually working larger bitsclose to donefinally done (but still needs a little cleanup)
Great job Ron, I am sure it was not easy or fast but the result looks very good. Frank
I like it ---that is one area of a tr3 I have not replaced. I see what you mean now about drill out the pins, nice job.
steve
DONE!!!
Well, I finally finished welding the new lower fulcrum pin in. I spent quite a bit of time yesterday rechecking the dimensions on the frame and leveling everything out using a 3 axis laser reference. I had a little panic attack when nothing appeared to be correct and after checking the vertical laser line with a plumb bob that I realized I left the laser head locked in position. :stupid:
I should note that one thing that was really helpful in checking a frame is a set of travel trailer leveling jacks. The allow pretty precise adjustments so accurately locate the frame reference.
The threads and pad pivot need to be greased to allow them to easily adjust.
Anyway, here's the process I used to install the lower fulcrum pin.
I first locked in the front of the pin with the removable fulcrum support bracket bolted to the original front frame mount bracket that was left on the frame during this whole process. To confirm the vertical location, I measured off the top of the fulcrum pin to the horizontal laser reference line after the chassis was leveled per the manual. The horizontal location was then measured from the centerline laser to the front of the fulcrum pin in the same manner. The measurements were within +/- 1/32" of what the manual says so I figured that was a good starting point. I then located the rear end of the pin using these dimensions and held it in place with an angle plate and some magnets. I added a couple of tack welds to hold the pin in place in the shock tower. After removing the fixturing parts, I proceeded to weld the pin in place. To ensure I got good penetration, I preheated the pin with a MAPP torch to around 300F and then maxing out the voltage setting on my 175A MIG, proceeded to weld. Rather than try to do the weld in a single pass, I did multiple passes biased toward the pin to get penetration and swept up into the bracket to tie in. Since I didn't have a clear shot to weld the backside, I made sure the welds were well knit but in hindsight, I probably got a little carried away and overdid it a bit. I'm pretty sure that pin isn't going anywhere. (sorry about the sideways images)
Once the pin was welded into the shock tower, I welded the front fixed bracket back into position..
And then fabricated the rear welded brackets that were cut away during the deconstruction and welded those into place.
Whether this is the factory-authorized way to do it, I don't know but I tried to document what I did so others might be able to improve on it. This worked for me and everything seems to be aligned correctly so it certainly is an improvement over the way it was and, as my wife often reminds me, "it was broken before you started to try to fix it so you can't make it worse".
Thanks for everyone's guidance along the way on this little task! Now on to the body...
Ron W
71 TR6
59 TR3A in lots of pieces
That looks great. Did you have to do both sides?
There was someone in Canada doing the same job a year ago. Do not remember if he posted completion photos.
David
Ron, looks like a fine job. Glad to see that you took your time, developed a game plan, and executed it. Job well done. My chassis repair was easy compared to the body work repairs . Good luck with your body work. Frank
Ron,
Thanks for being so diligent in your posts. Your content and pictures will be of tremendous help to folks facing this task in the future. I know it takes a lot of time to stop and document your work. Your efforts are appreciated!!!
Steve
Excellent job, I am actually less intimidated by the pin problem now after see your success and methodology, but still that looks pretty difficult.
steve
