I have been tied up on another project so I am ready to get back on Miss Eva.
Using the Speed Hut Gauges the Water Temperature sending unit would not screw into the Whitworth Threads in the Cylinder Head or Cross Flow Radiator.
I was able to get the adapter from Moss that is suggested to be used instead of screwing it directly into the head.
We were able to tap the adapter since the standard threads were very close to the Whitworth. The Tap was not able to go in as deep as I would have liked; however, with the low pressure it should hold the sending unit without leaking.
Hi Guest!
