TR2/3/3A Replace wiring harness in steering column
Redoakboo
I am trying to get the steering hub off so I can replace the wiring harness. I would just assume to keep the statur tube in place. I have removed the three set screws off the hub and the gland screw at the bottom, but can't figure out how to get the hub off the statur tube. I remember doing my TR-3 the hub, with the sleeve, Came right off of the top of the tube? I don't want to force it.
I have a wire connected to the old wires and wrapped with a shrink tube and would like to put them out from the top. I don't see anything in my manuals on how to get the hub off the S. tube?
Dick
charleyf
You have removed the only things holding the head onto the top of the column --if you totally removed the grub screws. If anything is holding the head down it is the wiring or just friction on the portion of the head that fits into the stator tube. Just try harder.
Geo Hahn
Geez - it's been 30+ years since I did this... but does the stator tube have to come out with the control head attached?
I recall a friend's Magnette has a 2-piece stator tube because there isn't room to pull the 1 piece version out in its entirely.
When you go pull the wires through the stator you may find it necessary to stagger the bullets so they are not alongside one another - or better yet, remove the bullets altogether.
R
Redoakboo
I removed the three screws holding the hub together. Need a new one as the insides were in pieces. I had bought a new harness at British Wiring, now i need the control head assy. I bought the harness as Moss didn't have the hub, with the harness. Now i got to try and find just the hub? Any suggestions?
Dick
charleyf
Dick
Try THE ROADSTER FACTORY You can get the entire set up and return the pieces back to other vendors.
Charley
CJD
Are we talking about the trafficator? If it was in pieces, then I assume you found the horn problem?
R
Redoakboo
I have installed the new hub along with the wire harness. My problem now is nothing is happening, after I make a wire connection. I hooked up the brown ground wire, from the hub, to the connecting brown/black wires to the horns. NO BEEP BEEP! I now have a green/white, a light green/red wire and a dark green/red wire left. Where do they go? I do have a spare green/white wire on the left side. It did nothing when I hooked it up to the hub green/white wire?
charleyf
You really need to consult a wiring diagram. In most of these cases you need to have two wires that are found in a 4 way plug that you plug the one (third)
same color wire into. That gives you one in and two out. Green /white is for the right side turn signals and green/red is for the left side. Yes brown/black is for the horns . The fourth wire is green/brown that goes to the flasher unit.
There are several online diagrams if you don't have a maintenance manual.
Charley
sp53
Hi Dick here is a picture of my car driver side. hope it helps
steve
R
Redoakboo
Steve, I have most of the wires according to your pic. Question: I know i have the Brown/Black wires for the horn hooked up correctly but, the horn will not honk? I have the green/purple wires connected too. I'm still working on the Green/White wires and the green/Red ones.
I have the right side Green/white three wires connected and seem to have an extra green/Red wire on the left side. Now if I have one side hooked up right, along with the green/purple flasher wires, shouldn't something work? I turned the key on but can't get the horn to honk or a light to blink? Do the all have to be set up perfectly for everything to work?
Do all the steering column wires make their connections on the drivers side? Are there any 3 way connections on the passengers side?
sp53
Dick there are extra wires in a tr3a harness from the factory for side blinkers. Those wires are not hooked up. No 3 ways are needed. Power comes in from green wire at flasher from fuse box to flasher itself. Maybe replace flasher. Remember the 2 same colored wires are hook ups for front and back lights of the same circuit and loop over to each side. Moreover; it might be best to say drive side and passenger side rather than left and right
CJD
The signals should work with the trafficator hanging loose...but remember the horn needs a ground, so the trafficator must be grounded to the column to operate the horns.
R
Redoakboo
Steve, I actually got the horns to work today. The fuse was not blown but only 4v were going through it. I swapped fuses and the horns now work. Before I attack the directional light wires, I need to replace the fuses. With no fuse in the far side, the ignition light will not even come on. I tried to find the fuse rating in the manual, no luck. Do you know what fuses I should buy?
Thanks, Dick
R
Redoakboo
Steve, I am almost there. Horns work and left blinkers, Green/Red, work. Still working on the right side. I have got a meter reading on all three green/White wires on the drivers side, but no blink? Should there be a extra wire coming out of the right Green/White wires to the right parking light? I thought all blinker connections were on the drivers side?
Jim_Stevens
There is indeed an “extra” GN (green) wire on the right side. You can see it in the schematic. It’s there for the RHD cars ISTR. If you have an extra GW (Green with White tracer) wire, that’s probably the place to start looking for the error. (I say that as an EE who made a couple mistakes in re-wiring!)
jim
sp53
On the drive side there would be 3 green and white wires 2 from the main harness and 1 from the sub- harness of the blinkers. Only one green and white on the passenger because it is the green and white wirer extension from driver side that came around. The blinkers need to get to the passenger side and that is why there are 2 green and white on the driver side. Look in the trunk and see what color you have for each side that should give an understanding how the front and back wires work together for the lights in one harness
B Should I replace my old wiring harness? Restoration & Tools 8
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
V MGB Replace late intake manifold angled breather with early model straight? MG 1
W replace rigid master cylinder lines with flex. Spridgets 2
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
B A plan to replace BE floor pans Spridgets 0
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
R TR4/4A Master Cylinder Corrosion Do I replace? Triumph 4
J TR2/3/3A replace brake and fuel lines? Triumph 4
J TR2/3/3A Replace rusty sills? Triumph 10
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
JPSmit replace shocks in pairs? Spridgets 7
JPSmit When do you replace things? Restoration & Tools 22
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
AUSMHLY When to replace spark plugs Austin Healey 1
drooartz MGB What to replace when engine is out MG 10
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
AHS BJ8 blower motor switch - how to replace? Austin Healey 1
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
TRMark TR4/4A Replace Water Curtain Triumph 5
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
S Replace original suspension for shocks? Austin Healey 2
J Replace the outside skin on a cargo trailer??? Restoration & Tools 0
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
7 How to replace door windows on a 77 MG Midget Spridgets 6
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
S Replace seal and dust cap BJ8 steering box. Austin Healey 23
gbtr6 TR6 TR 6 Head Studs, replace? Triumph 3
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
B Radiator - repair or replace? Pics attached Austin Healey 20
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
mailbox General Tech Fix, replace or rewire? Triumph 8
Kleykamp TR2/3/3A '61 TR3 Horns repair vs replace Triumph 15
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
britlover proper tire size to replace 5.90-15? Austin Healey 16
Rob Glasgow Replace clutch disk? Austin Healey 8
S TR4/4A Replace or rebuild heater control valve? Triumph 5
1 MGB Time to replace my top,,experienced recommendations welcome MG 10
R TR6 steering column removal bushing replace Triumph 2
