philman
I was reading in the shop manual and they have you raising the front end of the car and dropping the engine + subframe to the ground to remove. Is this really the best (easiest) way? Should I pull the radiator assembly first or is it easier to remove after the engine is clear of the enginebay? Sop manual has you remove it first, but sometimes they get things out of order.
My TR7 I raised the rear end and pulled the engine througn the top opening of the engine bay.
