Somehow I had no problem removing a TR-250 dash in the 1990s when I had no mechanical or tool experience, but now my '74 TR6 dash is being a pain. I've removed all the screws, the rheostat knob, the rocker switches, the retaining nuts on the washer pump and hazard switch...it still seems to be stuck between the gauges and steering column area. Not a ton of light in my garage so with a drop light, so I tend to miss small details (I need bifocals!) -- which means it might be something obvious to someone with better eyesight. Any ideas?
The dash is teak veneer with seemingly no varnish. There is some white staining on a section on and around the glovebox door. Any suggestions on how to best (and path of least resistance) restore the satin teak appearance?
Thanks,
Sam
Thanks,
Sam
