TR6 Removing TR6 dash [and suggestions on refinish]
sammyb
Somehow I had no problem removing a TR-250 dash in the 1990s when I had no mechanical or tool experience, but now my '74 TR6 dash is being a pain. I've removed all the screws, the rheostat knob, the rocker switches, the retaining nuts on the washer pump and hazard switch...it still seems to be stuck between the gauges and steering column area. Not a ton of light in my garage so with a drop light, so I tend to miss small details (I need bifocals!) -- which means it might be something obvious to someone with better eyesight. Any ideas?
The dash is teak veneer with seemingly no varnish. There is some white staining on a section on and around the glovebox door. Any suggestions on how to best (and path of least resistance) restore the satin teak appearance?
Thanks,
Sam
poolboy
If you have not yet removed the speedo and the tach, you'll have to..or at least the cables and the clamps.
Gliderman8
I completely striped the dash by sanding down to the plywood, then I bought a piece of walnut veneer and made a compression jig to adhere it. Then, lots of polyurethane and steel wool and finish
by polishing with rotten stone.
tomshobby
To remove the tach and speedo remove the round knurled nuts and clamps that hold the tach to the dash. Then remove the tach cable at the dizzy. Next pull the tach out from the dash and remove the cable at the tach. With the tach removed you will have a nice hole to access the rear of the speedo and with relative ease be able to disconnect the cable and remove the nuts and clamps. Assemble in reverse order.
S
sammyb
Okay, so unlike the TR-250, you have to remove the gauges for it to pop out. (Of course, that was 15 years ago, so my memory could be fuzzy.) I already loosened the nuts and removed the tach cable and speedo cable, so I'll just complete the removal of the clamps.
Thanks guys.
croz
I tidied my '74 TR6 dash up by removing it then smoothing/cleaning the surface with fine steel wool. For the finish I applied 5 or 6 rag coats of Danish Tung Oil. It sets up hard yet porous enough for touch up coats to soak in. The surface is more of a luster than a gloss. This method preserves the original finish and slightly deepens the color. Looks good.
DNK
Sammy- I helped a friend in the Covington (?) area buy some Koa for his dash and then the car was totaled.
He might still have that dash if you are interested
S
sammyb
Don, I don't want to go through the hassle of relaminating it if I don't have to.
Croz-- Danish Tung Oil is a bad name for dyslexics who read it as Tanish Dung Oil
DNK
Sammy- Dash has been done
So you would be swapping dashes.
Course, don't remember his year
HerronScott
Sam,
You should have to remove the speedometer and tachometer on any TR4, 4A, 250 or 6 to remove the wooden dash.
Scott
poolboy
Those 2 gauges are supposed to be clamped AND grounded to the steel dash and as long as they are clamped to the steel dash they ain't coming out and until they come out, it's just like Scott said..
glemon
When I refinished mine, which was in horrible shape, I simply chipped the old flaking varnish or shellac finish off, I used a heat gun on the stubborn parts, then I used an old "Homer Formby's Wood Refinishing Kit" that had some wood cleaner and conditioner, then I very lightly sanded, then I finished with gloss polyurethane, because of age I guess it turned out much darker than the original just with the poly finish. Was very pleased with the results and has held up well for about 3 years now.
PeterTR6 TR6 Removing doorlock TR6 without keys Triumph 2
2wrench TR6 Help removing an exterior door lock, '74 TR6 Triumph 1
2wrench TR6 Need help removing glass from '74 TR6 windscreen. Triumph 13
I TR6 Removing door check arm in TR6 Triumph 6
SCguy TR6 Removing from springs on a TR6 Triumph 18
G TR6 Removing heater from my TR6...... Triumph 14
Cain TR6 Removing TR6 Body Panels Triumph 27
Bill Redd TR6 removing engine, TR6 Triumph 12
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
