Hi Ed,
Thanks for your insight. I read your post and I want to offer back my 2 cents again and see where it goes, just to make sure we are on the same page.
When I mentioned about the hub waddling, etc., this was done with the drum off, but not to dismiss the fact the drums may be out of balance like you said. And I accept that. I will say something about them again later below.
But first, the axle shaft, as it is called with the plate welded to it and subsequently that very plate which is designed to receive the hub from behind with its five studs, is what I am referring to as the piece that is waddling and only as you view it head on or say, viewing it along the "X" axis (for argument sake). Not even the slightest waddling or gyration is noticable when viewing it from its side or the "Y" axis.
But let's assume the shaft may be bent, I wonder if it's a good simple test to have the shaft roll along the edge of a table to see how the hub plate or shaft, for that matter, behaves. Any other ideas on this??
I ordered new bearings to compare how they behave with the old ones, drag-wise. The existing bearings seem to have some drag or resistance when rotating by hand, indicating they may want to seize up in the near future. Otherwise, the physical makeup of the bearings appear excellent.
As for the drums, while installed, I would rotate them by hand to find they do hit a hard spot on the shoes (or pause, if you will) and I do believe this is a direct result of the hub shaft plate mentioned above. Maybe you are implying that because of the out-of-round effect of the axle shaft that the balance can be compensated by fixing the drums? And yes, while driving, I also sense this type of pulsation when stepping on the brakes, though not dramatic. Still, I would like to learn more.
The axle case, I feel is fine or otherwise, I would experience looseness where the bearings are positioned which are not and again, refer to my "X" and "Y" findings above.
My first and foremost BIGGEST concern at this time is, is if that klunking sound is going to come back? And if so, what's next? I will only be able to say more when everything is back and the car is on the ground for a test run.
BTW, what weight lubricant do most agree to go with for the axle?
Thanks.
Paul
