Chet Zerlin
Hello all. I'm in the process of trying to remove the transmission cover from my 2 seater 100-6. As much as I try I can't get it to clear the handbrake - and as a result I can't lift it up high enough to get it to clear the shifter (so that I could lift it out enough to get the "lip" out from under the handbrake). Kind of in a Catch 22 situation...
Do I need to remove the handbrake in order to remove the cover or is there another way that I'm simply not seeing?
Thanks in advance for your help!
Chet
Chet
Hi Guest!
