So I may be getting in over my head now, now I'm starting to have some second thoughts, but I'm too stupid to think other wise. So I've ordered some floor panels in, should be here by Monday, so I started to look at the floor and what I'll need to do to remove it...... So I stuck my hands in and pulled, at all came up except for a couple of spots, so I cut around them with tin snips, so now the floor is up, for good or bad.
So I started to drill out the spot welds in the door opening, have most of them off now just a couple at the back edge I'm fighting with, but they will be off soon I hope, and I was looking around for some easy welding to do when I noticed that the front body mount is cracked and almost rusted thru, and the little bit I can see of the rear one it's looking the same. The "A" post is good except for the last couple of inches at the floor level, the fire wall where it angles down to the floor is the same, last couple of inches seem to be rotten. The rocker panel is rotten and pulling away from the inner sill at the bitter edge of it's so I'll be ordering a set if those as well, or patching them if I can. The inner sill looks good, just surface rust or so it seems won't know until I start cleaning up getting ready for paint and welding.
So now where do I begin in the welding?
Do I get the rest of the floor up ( drivers side) and repair the body mounts first? Or do I install the floor and then do the body mounts? Or is now a brace the living crap out of it and lift it off the frame, and then start where?
So far I've only started on one side ( driver), the passenger side is still rotten metal.
Thanks
Thanks
