AEW
Down grading an engine system is risky. Crankcase venting is one of the best pollution reduction designs invented. California fought Detroit for a decade to get road draft tubes replaced with engine vents that recycle the internal blowby and oil vapors. That battle is legendary.
Adding a home-made system is also risky. Chances are you won't sort out how to make it function at all RPM and road speeds. The reason the old TR2, TR3, TR4 vent tubes are such an odd shape is because they went through a lot of trials and do overs. Sorting out how much crankcase pressure is needed is tricky. If you don't want to mess up oil flows to seals.
I think if there is too much liquid (condensed oil vapor and blowby fuels) in the air cleaner look at the source. Are the rings shot? Is there too much oil in the pan? Are the oil return passages in the head blocked with carbon? Is the head gasket blown?
If you feel you have to do something creative then install the catch tank in the hose to the air cleaner.
