David: Nothing will fit in front of the radiator. You can do a few things, run the TR tropical fan (if you can find one), but a yellow fan and mount it backwards to fit, run a TR6 red fan, install a puller electric fan and delete the TR3 fan all together.
I have used a 160* thermostat for several years. Works good in the summer--but come the cooler days and the car runs below temperature that is recommended. Which I understand is 185*. I am now back to the 185*.Would the 160* thermostat be a help in the hotter areas of the US like Georgia?
David
Good one.When I had that fan I ran it with a generator.
I don't recall the numbers but I did measure the draw and decided if I didn't turn on the fan, listen to the radio, use the headlamps, run the wipers and honk the horn all at the same time -- I would probably be okay.
...it looks like there might be some blockage of air flow with the fan off, were you able to notice any change in the cooling efficiency when you were not in stop and go city traffic?
Hi Folks,
I've had similar overheating problems in slow or non moving traffic. I'm running a 185 Thermostat & probably will install a 165 for Summer use. I also bought Mark Macy's fan & mounting kit but have'nt mounted it yet. I really don't want to remove the apron to do this! Is it "ABSOLUTELY NECESSARY" to remove the apron to mount Marks fan? I currently have a 12" Elec fan mounted on the front of the Rad. In a pushing mode & does help bring the temp down. Any & All input (Again) will be greatly appreciated relative to the front apron removal or not.
Thanx, Russ
I have seen several mentions of plugging or partially plugging the bypass. Is plugging completely better than restricting the flow?
David
...Is it "ABSOLUTELY NECESSARY" to remove the apron to mount Marks fan?
