My overdrive does not function, click, smoke, or engage. I never really had the OD checked out before I installed it beside taking the cover off of the Trans and checking for broken teeth. The relay was replaced and the solenoid cosmetically cleaned. The switch is an old oval switch that I took apart and cleaned and it should work. I followed the wiring diagram in the book and there is a fuse.
I am going to start trouble shooting the problem and my first thought is to take the switch out of the circuit and bypass the switch by touching the wires together and see if the relay clicks or solenoid does something. I have never owned an overdrive, so my questions are going to be out there. Anyways any help would be helpful
Steve
Steve
