Well, we got the fuel problem solved but noticed that one fitting at the "T" in the brake system was dripping a little bit. Tightening it made it worse so we took it loose and made sure it seated properly. Of course then we needed to bleed the brake lines. Fluid just sort of "runs" out of the rear lines and squirts out of the front calipers. Brakes are now pretty much crap even though they worked fine with the slight leak. We are at a lose(sp?) as to what we should do!! Any suggestions? Thanks
