carpecursusII
Just a matter of note, your parts list had the oil pump and rotor and the oil pump assembly, you likely only need the pump and rotor. +1 on balancing everything, that will really change your life. I use copper F8 gaskets and use permetex aviation gasket sealent to put them in, its a gooey substance like thick molasses. Also +1 on the rear seal conversion from The vintage racer, Joe is a great guy and will give you a better price on the parts than TRF. The seal is easy to install, just check the length of your flywheel bolts, they will need .100 ground off them more than likely to clear the lip seal. I would also replace the cylinder head nuts. Be sure to check your crank float inside the block, I know you have STD bearings listed but you may need .005 oversize to get in spec. If your going to replace the timing chain, absolutely replace both the gears, old gears will wear out a new chain much faster. Get on youtube to understand how to time a new camshaft/gears when you reinstall, its tough to wrap your head around the first time but it will come. I also only put permitex on one side of the oil pan gasket and use silicone on the other side so that it will seal but I can remove the pan without needing a new gasket. Your machinist was correct, your clutch disc looks good, you may want to have your pressure plate surfaced, I can't tell how bad it looks.
