New fuel pump - loud ticking, now fuel spraying!
BrandonBJ8
After I converted to negative ground last weekend, I realized that the diode in my old fuel pump was blown. I have a spare negative ground pump that I decided to install just now. After installing it, when I turn the car on, it has a loud constant ticking. I thought it was just initially to get fuel flowing through it, but after about 30 seconds it kept doing. I started the car and it started fine, but I the ticking did not stop. Any ideas?
Thanks!
Cutlass
Re: Installed new fuel pump - constant loud ticking??
Could it be cavitating? That happened with me recently, upon first start after rebuild. I just loosened the fitting on the engine side of the pump, let it run for a couple of seconds, till gas came out. Apparently that cleared the air in the pump. No problem after that. Those who know more will probably point out the danger of flowing gasoline that near an electrical pump, or that what I did had nothing to do with the problem, but hey, we're all learning.
B
BrandonBJ8
That makes sense. Is there a safer way to get the air out of the system than loosening it at the fittings on the pump while it running?
Cutlass
I wouldn't do it with the engine running. Sorry I wasn't clear on that. I just did it with the ignition switch in the "on" position. I also bled the system at the carbs.
B
BrandonBJ8
That's what I meant, with the pump running, not the engine. Anyone know if this is the proper thing to do?
B
BrandonBJ8
I just went and re-checked all the fittings and they are nice and tight but it's still making the noise.
Keoke
Hi Brandon, on some of these new pumps they come with "O" rings instead of the old paper type gasket. Additionally the mounting bosses on aftermarket pumps are a bit shorter than the originals. Consequently it is possible that even though the fittings are tight the banjo can be cocked on the boss ever so slightly allowing the pump to pull air. I would add the paper washers in addition to the "O" rings and see if the pump does shut off correctly. Fwiw---Keoke
B
BrandonBJ8
Keoke, should there be a washer on both sides of the banjo? Currently, they are just on the line side and not the pump side.
B
BrandonBJ8
So I just went back and tightened the banjos even more. I think the inlet side was sticking so it was able to go in even further. I then started the car and the ticking slowed down and quieted. I got out to check on the fuel pump and it was spraying fuel out everywhere!!! I think it was coming from the fitting areas but I was so surprised that I ran to shut off the car first. Does this sound like the banjo fittings are just not tight enough? ( I tightened them about as tight as I could)
B
BrandonBJ8
I took a picture of it while its on and off. Looking at it on it almost looks like I tightened it too tight and it loosened up the body. Any ideas?
Keoke
/bcforum/images/%%GRAEMLIN_URL%%/savewave.gif- /bcforum/images/%%GRAEMLIN_URL%%/yesnod.gif
Yes to properly seal the banjo washers should be used on both sides. /bcforum/images/%%GRAEMLIN_URL%%/nonono.gif Do not overtighten the banjos or you will strip the pump's threads.----Keoke- /bcforum/images/%%GRAEMLIN_URL%%/hammer.gif
If you look closely you will see that the lines are binding on the pumps housing because the pump's bosses are shorter. By tightening it you caused the tilt to be more sever. Leave the "O" rings in if they are ther and also add the paper washers.
B
BrandonBJ8
I figured it out. There was a screw on the pump housing that was loose. That combined with the pressure from the line pressing against the pump caused it to be an even larger gap. I pushed the fuel line away from the pump and tightened all screws. It's running well now with no leaks! I'll have to go pick up some paper washers though just in case. Thanks for the advice!
Dave Richards
That ain't right! I just replaced my pump last summer. If the fittings are leaking, they're probably shot, maybe cross threaded, others more knowledgeable will know...
Keoke
Naw Dar100, he be ok now!---Keoke
Cutlass
I was told that it takes a couple of gentle tightenings with the new paper washers to get them to seal. Of course, the banjos go on only one way correctly. The recessed part of the banjo itself is on the outside. The bolt holds one of the two paper washers into this recess. The pump side of the banjo is flat, with another paper washer. My new washers seeped a bit of gas with the first few engine run-ins. Slight, careful re-tightening, with the washers now saturated, stopped the seepage.
Keoke
Yes that is true Cutlass. However, the new pumps do not have flat surfaces for the banjo to rest on and they have shorter fuel bosses. Additionally, they have an "O" ring recessed in the end of the fuel boss. Consequently, there exists a thin lip around the out side of the "O" ring that can be damaged when the banjo is tightened and the fuel lines bind on the pump's body. Adding the paper washers in addition to the O rings generally moves the lines Far enough away from the body to alleviate the binding and provides a more secure surface for the banjo to seal against.--Fwiw---Keoke
Dave Russell
Yoda - R.I.P
Guess I'll get in on this also. The black fiber washers from Nock's are a little thicker & softer than the standard red washers & far easier to get sealed.
Keoke is right on about needing an intact O ring in the pump recess plus a fiber washer next to the banjo. As was said, flat side of the banjo toward the pump, washer, & O ring. Recessed side of the banjo with a fiber washer toward the head of the banjo bolt.
I skipped this whole mess by screwing hose barbs into the pump & using short hose connections.
Keoke
Now hows you did them rubber things, did you add a ground from the fuel tank sender to the car chassis?? I don't know who said that!---- /bcforum/images/%%GRAEMLIN_URL%%/nonod.gif
----- /bcforum/images/%%GRAEMLIN_URL%%/savewave.gif
Note: *to all who have replaced a fuel pump* It is imperitive that you add a Grounding conductor from the Fuel tank's sender housing to the cars Chassis. This applies whether you have utilised rubber hoses or just the sealing washers.--- /bcforum/images/%%GRAEMLIN_URL%%/hammer.gif--Keoke- /bcforum/images/%%GRAEMLIN_URL%%/yesnod.gif
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
sundown TR6 Fuel pump Triumph 10
