kennypinkerton
Re: My Toyota - Reassembly!!
Yeah, hopefully the superglue will hold the 2 broken plastic vacuum fittings. I spread lots more across them after setting them in place - hoping to make sure that there is no heat-breakage or leaking from the glued plastic tubes.
And yes, The world did seem to come to an end, for a day or so. I've managed to come here at least once an hour while the site was down with at least 4 different update pics.... But I figured I'd wait it out. BCF is the best site on the net!!!!
On the engine... I have yet to install the upper intake manifold, the throttle body, the alternator, the fan, (fix the small hole in the radiator - with solder over the small hole - if any other sugestions, please make them quick), the filter/hose intake system, and I should have a new truck again!
Hi Guest!
