When posting a classified ad, you MUST select a prefix from the drop-down next to the subject line. If you don't you will get an error and your ad will not be posted!
From what I have read, to get to the headlight mechanicals and electricals is throught the headlight body cavity.
For all you headlight experts, is this true? If so, how do you remove the headlight cover with the headlights in the down position (I can't get them to pop-up).
Need some help!!
Thanks
If you'll check underneath the apron where the pods "live",
there is a knob you can rotate to raise each pod manually. Turns counter-clockwise, I believe, and if you continue turning in the same direction, it will lower it.
