GBRandy
I need to look at some old notes, but it sounds like you have a ground issue. It can create all kinds of bizarre things.
The ones I would attack are:
1. The ground in the trunk from the negative batter terminal to the body. Get a new length of wire.
2. There is one in the engine bay on the R/H side from the frame to the engine block. It is an unwrapped braided wire. It is a B&*^ to get at the connection on the engine block but you can get at it from below. I scrubbed mine nice and pretty while the PS was out
3. There is at least one under the dash. I do not recall exactly where at the moment, but it does give fits as it relates to switches, lights & other abnormalities. i would get under there and look for anything attached to the frame and clean it.
If that fails I would pull the alternator and bring it to a quality rebuild shop for a bench test or better yet a new rebuild.
Lastly I would pull the battery and have that tested as well. For me, if the battery is 5+ year old, I would simply replace it. It takes that out of the loop and it needs to be replaced soon anyway.
Beyond that, you are into wire loom issues, relay problems, etc.
