Wedge My new toy: 1981 TR-8
Tony,
I'm afraid I am not good with electrical work. When you say 'jumper', what do you mean and how do I use it?
When I have the switch out, how do I test it? Are there examples and/or discussions on this or other sites?
Thanks
From what I have read, to get to the headlight mechanicals and electricals is throught the headlight body cavity.
For all you headlight experts, is this true? If so, how do you remove the headlight cover with the headlights in the down position (I can't get them to pop-up).
Need some help!!
Thanks
Mike -
If you'll check underneath the apron where the pods "live",
there is a knob you can rotate to raise each pod manually. Turns counter-clockwise, I believe, and if you continue turning in the same direction, it will lower it.
