Caution annoyed rant coming up!
My car has obviously learned its lesson from crypty (or since it has been on blocks for 2 years now, maybe it taught crypty??)
Since I bought it, I replaced the diff ( I knew that was junked when I bought the car), the gearbox (large bits of the roller bearings in the oil) and then after 450 km of driving the engine lost all compression after it overheated and when I opened it up, I found that it was bored to the max, and in bad shape.
I got a different block, only .02" over and since it was rather filth inside, brought it right over to be machined. We had to go to .06" to get a good straight bore. Ok, I can live with that.
I finally got the block back in, and go to put the head on (I also rebuilt that) I ordered "heavy duty" head nuts, since Heavy duty is obviously better right? At 30 ft-lbs one popped. I replaced it and then at 32 a second bolt CRACKED. I talked to my supplier (one of the major triumph suppliers in the UK), and they said they have had no problems with these nuts, and use them in their shop all the time. But then odd, and they claim to have never seen this, but the nuts I got were somewhat oversized. (I needed a 15mm socket instead of a normal 9/16) They also told me they had never seen this. (They did send me new nuts no charge, and amazingly, they were the correct 9/16 across the flats)
Now today, I put in the new nuts, tightened everything to 30 ft-lbs, and new one suddenly goes soft. Now this may be my fault for reusing the studs esp after the crummy nuts, but they looked ok. So I replace the stud (with a different used one) and put an original nut back on. Then on my final "make sure everything is tight" another one started to move. Now fortunately, I stopped the wrench before I think I did any real damage, but this does NOT make me real happy. What I am planning on doing is just putting a second nut on top to lock it in place and leaving it that way.
Frankly I am getting tired of seeing this car in front of my apartment every time I walk outside. At least the flywheel run out was in spec after I tightened the bolts. I put the cover back on and am not going to look at the beast or anything else triumph related for a day or two!
