Spitfire Misc GT6/Spitfire Questions
UmmYeahOk
Ok <span style="font-weight: bold">first</span> one is Im having problems with my GT6 smith tachometer. I dont know if its broken, or just poorly installed. The distributor cable is brand new. When the car is idling, the needle slowly sways back and forth from 7000 to the 0 RPM stopping pin. (area on the bottom without numbers). When the car is turned off, the needle rests on the 7000, 5000, and sometimes 0, and in rare cases, will slowly move to other numbers when the car is off and when originally rested around 7000. If the needle were poorly installed I would just assume it would still function normally, just higher RPMs than usual. Instead its behavior seems to be completely random.
<span style="font-weight: bold">Second</span>, I was wondering if someone with an early spitfire could tell me how long their round knob choke cable is. Please dont go uninstalling for my sake. But if someone just happens to have one uninstalled, it would be awesome if you could measure it for me.
<span style="font-weight: bold">Third</span> - Early GT6/Spitfire interior question: I was wondering if someone could please get me the dimensions for #66 if their car still has these.
https://www.canleyclassics.com/?xhtml=xht...mp;showsubs=yes
Thanks.
TR3driver
Great Pumpkin - R.I.P
Many new cables have the inner cable protruding too far from the outer cable. That can put pressure on the gauge mechanism and make it malfunction.
Try taking the connection partially apart (ie if it's a nut, unscrew the nut a few turns) and see what difference that makes. If it doesn't change the problem, then the mechanism needs to be serviced. Not necessarily 'broken', it might be as simple as oil where it shouldn't be, but something is wrong.
Sorry, can't help with the others.
dklawson
I agree with Randall on the tach. I suspect it is the cable.
I could be wrong bit I think our car has the "wing" type choke knob with a carb butterfly symbol on it. Our car is under covers at the moment but when we next dig it out I'll look at the cable length for you.
It took a while to find #66 in the linked diagram. Those look like trim/skinny versions of the knee pads used on later Spitfires. They were not on our GT6 when we got it. If they ever were there... they were removed by my father-in-law years and years ago.
ArcticOne
On my 68 GT6:
Front and Rear: 3 1/2 inches wide (slight curve to profile so not exact)
Length: 26 inches
6 inches from the rear is a 1" x 3 1/2" oval shaped hole through which the seat belt feeds through.
The cover starts at the front of # 65 and ends at the rear of # 63.
Sorry for the imperial measurements, but it was the handy tapemeasure.
Can post some pics if needed.
jb
UmmYeahOk
UmmYeahOk
Thanks everyone! For some reason the batteries on 3 of our 4 vehicles are dead, including the triumph, so when I get that sorted I'll see if that'll fix my tach. I'm hoping that's it.
As for the interior pieces. My guess is it was intended to be the inside bolster of the seat. Many early MK1s I see have these missing. I don't know if they were removed to accommodate a larger rear end, or if they were just prone to damage. But the pieces they cover always show wear like something belonged there, because it did.
I think you're right. All the pics Ive found have it, and my owners manual has it too. I guess I said "round knob" because that's the one Victoria British sells. I currently have a $11 universal one, but would love to be able to use my old "wing" pull and chrome bezel. The choke cable I got may have not been for a GT6, or at least a MK1. It controlled two cables rather than one, the longest of the two operated my choke until my husband pulled too hard on it (frayed wires got stuck)
UmmYeahOk
UmmYeahOk
Thanks a bunch. Being a 60s british car, inches are preferred. I simply cannot have anything metric on my car (at least with this one) =)
I am making all my body panels myself, and these are the last pieces. Pics would be awesome, but I don't want to trouble you.
ArcticOne
A number of pictures will follow - tough at one per post.
Towards the bonnet
ArcticOne
Towards the boot
Can't get it all in one shot as the seat is in the way. Will take it out for some better pics.
ArcticOne
More detailed measurements:
Overall length: 26"
Front width: 4 1/4" ish
Middle width: 4 1/2"
Rear width: 3 1/2"
Measurements are not the best as it is not a flat piece, but more formed / shaped to hug the tunnel cover.
It is a very heavy plastic / rubber piece (almost 1/4" thick). Mine has a leather / leatherette covering.
I would not use mine as a template as I think it was hand fashioned. Likely best to measure up your particular car and also figure out how high up the e-brake console you want it to ride.
If you need anything else please let me know.
jb
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
N Misc Spridget parts Spridgets Classified 0
R For Sale Misc. TR-4 signal and flasher parts Triumph Classifieds 0
Northcoaster For Sale misc TR4-4a parts Triumph Classifieds 3
Johnny For Sale misc. AH parts including Sprite. $25 plus shipping. Austin Healey Classifieds 3
Zimmycobra For Sale Misc. External Engine Parts - 1966 TR4A Triumph Classifieds 1
M Wanted Misc TR3 Parts Triumph Classifieds 13
aeronca65t Misc. Rare Brit Cars Other British Cars 3
aeronca65t Misc spotted Spotted 0
5 1953 100 misc component colors Austin Healey 2
aeronca65t Misc Spridgets-Watkins Glen Spridgets 2
PC random misc. Spotted 0
racingenglishcars Old ads and misc ramblings Spridgets 4
Johnny Misc. BJ8 car parts just listed in Classifieds. Austin Healey 1
aeronca65t Other Brits-misc Other Cars 0
aeronca65t Other Brits-misc Other British Cars 19
tomshobby some misc stuff Triumph 1
SilentUnicorn T-Series TD misc. parts MG 7
WALTER Rear spring misc. Austin Healey 6
G MISC Q's: BT7 Tranny, Tighten Steering Wheel, Rattle in Front End Austin Healey 11
G Misc Questions re Overdrive and Exhaust + Up-date on Redline Oil Austin Healey 7
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
C GT6 GT6 fender flares Triumph 0
B GT6 trying to ID my New Car. GT6 Triumph 6
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ‘72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
idlehands Wanted GT6+ Triumph Classifieds 11
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
B Wanted wing windows gt6 Austin Healey Classifieds 0
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
H GT6 GT6+ seat panels Triumph 2
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
R GT6 Looking to purchase GT6 Rust repair question? Triumph 4
R GT6 Triumph GT6, basic work estimates Triumph 76
