Hi Guest!
If you look at the Midget pan photos you can see that the depression for your feet is only defined at the very front the rest is just bowed.
It always seems to take that double check with the bender, as in itself it's a diabolical device!Trying to decide which side of the pipe the bender should go was a bit like trimming your beard in the mirror. I always turn the scissors the wrong way.
I did make a tool to get my pipe straight before I started with the bending. The dowel is only to demonstrate how it works.
I recognized the legs and quick-release locks. Got my Bogen 3033 well before Manfrotto & Bogen got together, did an "Ala Carte" combo with the 3126 fluid head. Have their monopod and "Magic Arm" as well. Good stout pro gear!It is a Manfrotto 3160 distributed by Bogen. I got that years ago when out daughters were at school and I did a lot of videoing. Got tired of the cheap tripod slipping or breaking.
Still amazes me the way some things were (and some still are) tossed well before their time. Good for you in re-purposing those!I made the bender from parts salvaged from one of the machines the company I worked for made. When ewe did an overhaul on the machine those guide rollers got changed and for some reason they always changed the shafts as well. I would keep some thinking they will come in handy one day. They did.
