Russ looks like your just going to have to get in there and do it or summer will be over.
The original tropical fans are indeed rare, but the fan used on some GT6s is very similar.
Here is an example on ebaY right now: TRIUMPH GT6 METAL ENGINE FAN BLADE
...i just noticed that I have a "7lb" Rad. Cap.
Question: Isn't 7 psi standard, for most TR4?You might compare the reach of your cap (the part that extends down into the neck of the radiator) to the depth of the radiator neck (down to the lip the rubber seal should go against). Most modern 7# caps are about 3/4" whereas original TR3 necks are more like 1".
Question: Isn't 7 psi standard, for most TR4?...
My point was just that long reach 7 psi caps are readily available, I think. At one time, it was the only replacement made by Stant (probably not true now, though).His avatar shows a TR3A.
Not sure what you mean by "prolong", but in general, higher pressure improves cooling. It both increases boiling point of the coolant (roughly 3F per psi, IIRC), and helps improve thermal conduction between the water and radiator tubes (as well as engine).
I'm actually running 10 psi on my TR3; which may be why I had several failures of the upper radiator hose before switching to the "heavy duty" Gates hose.
Definitely worth a try. It helps guide fresh air into the radiator, instead of letting the hot air recirculate.By the way; I "DO NOT" have a "Shroud" mounted. I wonder what that would do? "Can`t Hurt"!!
