Lubricating Leaf Springs
Michael Oritt
If I were going to the trouble of removing and disassembling the leaf springs I'd trim pieces of either the zinc or teflon sheets referred to earlier in this string rather than paint or lube them.
LarryK
In the early years they made leather gaitors to cover the leaf springs and there were Zerk fittings on each end to fill the gaitor with grease. The gaitor kept the grease on the springs and not on the ground. Have not researched lately to see if they are still available.
LarryK
Accents unlimited still makes them. Custom fit.
kodpkd
Has anybody tried the leaf spring liners? Cut to fit. They might add a bit of height also.
LarryK
Looks like my garage door seal.
HealeyPassion
Has anybody tried the leaf spring liners? Cut to fit. They might add a bit of height also. View attachment 86495
I've installed them. The car is undergoing full restoration and it's not on the street yet. Write up was in November 2022 HM.
kodpkd
There are other liners that don't have such a large edge on them. I think they would look a little better on the finished spring.
T TR2/3/3A Instructions for cleaning & re-lubricating speedometer? Triumph 5
KVH General Tech Lubricating New Rod Bearings Triumph 7
T Lubricating the steering rack on a Bug-Eye Spridgets 12
TimK Lubricating Speedometer drive Austin Healey 11
P Lubricating a new BJ8 water pump Austin Healey 3
T lubricating a pilot bushing Spridgets 9
M Lubricating the front suspension Triumph 25
T QUestion regards lubricating steering rack Spridgets 9
rchakr Lubricating Water Pump Triumph 2
S Lubricating Speedometer Cable Austin Healey 13
G Should I be lubricating my Strombergs? Triumph 8
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
B Disassemble quarter eliptical leaf springs Spridgets 6
F TR2/3/3A Leaf spring advice Triumph 16
Editor_Reid Unusual Leaf Spring Austin Healey 4
D TR2/3/3A Leaf springs creaking Triumph 6
D Another use for a leaf blower. Restoration & Tools 1
Keith_M Bugeye rear leaf springs Spridgets 19
B Leaf Spring Re-build Options? Other British Cars 2
F TR2/3/3A Leaf Springs Triumph 57
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
D TR2/3/3A New Leaf springs. Triumph 21
C Best Replacement BN1 Leaf Springs Austin Healey 5
J Leaf springs Austin Healey 2
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
KVH General TR What Happened to My Leaf Spring's Nyloc Nuts? Take a Look . . . Triumph 17
B BJ8 leaf spring Austin Healey 2
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
Joe Reed MGB Colorbond Autumn Leaf paint MG 1
S Any recent experiences with rear leaf spring vendors? Austin Healey 31
K TR2/3/3A New Moss Rear Leaf Springs Triumph 7
GTP1960 TR2/3/3A Should you paint your leaf springs? Triumph 5
GTP1960 TR2/3/3A How long do leaf springs last? Triumph 8
K TR2/3/3A Leaf Spring "rebound clip" thickness .... Triumph 16
K TR2/3/3A Moss rear leaf springs? Triumph 19
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
K TR2/3/3A Leaf Spring height and front spring pin removal again? Triumph 1
K TR2/3/3A Moss "competition" leaf springs? Triumph 9
C Leaf spring length Austin Healey 4
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
T TR2/3/3A Leaf Spring "Silent Bloc" Triumph 3
RAC68 Quiet Leaf Springs Austin Healey 4
B Installing New Leaf Springs on 100-6 - Am I missing something obvious? Austin Healey 19
stuntflyr Leaf spring toe-in modification viability Austin Healey 19
