Gotta ask ... If you cut the end off the bolts, how do you drive the bolt out of the bush? That's where they get stuck. I've used a crowbar to lever them out; yes, you have to re-flatten the big end of the bolts/pins before reinstalling.
Get two sockets:
One with the inside diameter just a wee bit larger than the outside diameter of the bushing.
The other one with an outside diameter of the busing.
Set the wishbone on top of # ! and Place @2 on top of the bushing drive bushing out use Led hammer OK.
This works on rear spring bushes too----
tried this, didnt work so I resorted to the gas axe . Set up my portable workbench outside and heated the wishbone till the rubber caught fire and the remains of the bolts and bushings fell out .
Is there, or would it benefit from, a grease track on the bush ID?
Danny
The next person to take mine apart will find the same thing (Kopr-Shield by Thomas & Betts).A bit OTT
I just put copper grease on mine before reassembling.
