Deleted member 21878
Lilly Engine up-date / couple of questions
Everything went pretty well today. plastigauged all the rod bearings and all were right at the .003 mark. So at the top of the gap range but within spec. So all new shiny nuts on the bottom end are a good thing. i also put on the new timing chain and new tensioner. Got the covered installed before it was time to give it a rest. Hope to get a couple of hours in tomorrow as well.
2 questions:
1) how tight do you all normally put the carnk dog nut? i know it took a pipe on a pipe wrench to get it off but that may have as much to do with age. i could not find any spec on it. Turn it as tight as i can and then lock it?
2) also was wondering how tight you all torque the oil pan bolts. same as the front cover?
Hope to put the new oil pump in tomorrow and the oil pan. then it is on to the head. any suggestions or tips on these two jobs is always appreciated.
Thanks
2 questions:
Thanks
