You must be trying to remove the pin in the lever on the passenger side of the gearbox. I did not remove that side lever only the plate on the drivers side.
The pin is probable a taper pin so you have to drive it out from the small end. They make Pin punches for that purpose.
Be careful to not bend the shaft.
David
David
