TR2/3/3A Leaking O.D. section of Transmission
R
Redoakboo
Seems that there is a seal behind the setting lever on the passenger side of the OD that is held in place with a roll pin. You may be able t replace that.
The one on the solenoid side you just have to remove the plate and replace the "O" ring.
David
David,
have you any idea where you can buy those two "O" rings? I think I found one in Moss cat. but not positive? Dick
titanic
I remember seeing a tech tip on another forum about replacing the pin on the setting lever with a socket head screw. I believe it is a #6 or #8). The lever must be drilled&tapped and a portion of the screw mus
DavidApp
The "O" ring in the plate I have in the photo is not a standard o ring it is a square section ring. I do not remember if I got it from Moss or Rimmer. They both call it an "O" ring and call for 2.
Do not get any sealer on the "O" ring r shaft as it has to turn freely for the OD to disengage.
David
CJD
There is an interesting feature of the new website. I started typing the below response yesterday, but must have not hit the post button. It saves your typing! Anyway, with my delay, David beat me to it!...
The diagram gives the impression the o ring goes on the outside of the solenoid cover. It actually goes on the inside.
R
Redoakboo
John, do you know of a repair shop that works on speedometers?
Dick
R
Redoakboo
David
I have removed the outer cover next to the solenoid. Apparently I need to now remove, what Moss call the 866-340 Bracket, to get to the O ring location on the backside? I see there is another gasket 866-350, I need to get too. Dick
DavidApp
I presume you must have a cover over the solenoid lever?
This is how the later ones look there is no cover over the lever so yes you will have to remove the Bracket and may need a new gasket if it gets damaged. I made one from gasket material from Advanced Auto.
David
R
Redoakboo
Is that bracket easy to take off and on? Are there any springs that are going to come out, when I loosen the bracket? From the earlier pic you sent me, I assume the "O" ring mounts in the back side of that bracket?
Thanks David; wish you lived next door.
Dick
DavidApp
The bracket comes off easily but you will need to unclamp the solenoid actuator arm. There is the big accumulator spring but it does not jump out.
Be careful how you apply gasket sealant as the shaft needs to rotate freely.
David
R
Redoakboo
David
Thanks David,
Might lose a little oil?
Dick
R
Redoakboo
How did you get the pin out? I have bent 4 nails trying to drive it out. Dick
titanic
Sorry I didn't complete the original posting, I meant to delete it and couldn't.
A nail set or hardened punch may be a better weapon to remove the pin. I don't think it is tapered, so it should be possible to remove it from either side after removing any peening.
Berry
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
S Leaking HD6 Rear Carb Austin Healey 10
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
S TR2/3/3A rear main seal is leaking Triumph 13
E Oil leaking from the Tachometer cable Austin Healey 5
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
drooartz Leaking 5-speed drain plug Spridgets 26
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
D BT7 rear wheel leaking Austin Healey 25
N Leaking Carburettor Austin Healey 11
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
C TR6 Brake servo leaking Triumph 3
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
R soft plug leaking Austin Healey 45
George Zeck Master Cyl Leaking .... Spridgets 5
M TR2/3/3A O/D brass cap leaking Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
rjc157 Leaking steering box Austin Healey 4
B mysterious leaking of SU HD8 Jaguar 9
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
B Rear Engine Side Cover Leaking Austin Healey 9
D Overdrive Leaking Oil Austin Healey 4
KVH TR4/4A Oil Pressure Banjo Nut is Leaking Triumph 6
H TR2/3/3A Leaking Fuel Pump Sediment Bowl Triumph 5
PatGalvin TR2/3/3A Leaking SUs. Advice badly needed Triumph 15
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Michael Oritt Leaking oil pan Racing 8
T TR6 leaking carb TR6 Triumph 17
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
Rob Glasgow Leaking tapered plug on head Austin Healey 8
Scotsman TR2/3/3A leaking front engine plate Triumph 4
bigbadbluetr6 TR6 Carb leaking Triumph 12
M TR2/3/3A Head gasket leaking in two places Triumph 13
Boggsy64 MGB Stormberg leaking like a sieve MG 4
