DNK
AweMan said:Were it me I would remove the oil filter/canister { which ever the case may be} and drain it. It may take a couple of times and restarting the engine each time after you drain the filter doing it this way to get the amount you want out of the crankcase.
In SD1 motor,bad idea to let the oil pump drain. I think that is what started this in the first place.
gjh said:...Do you have OP gauge? How is the PSI?...Good luck.
The oil pressure I posted somewhere. It was OK at speed ,a bit low at idle.
Can't remember where I posted it.
