mbrooks
Whilst checking the shock mountings [yes they were all loose], I also did the test for worn kingpins for the first time. there was plenty of movement. The kingpin bushes are very worn. The manual says the new bushes can be drifted in, but they need reaming. Is this a job I could do? Where could I get the correct reamer?
Alternatively, if I need to entrust this to a machine shop, can anyone recommend someone in the Houston area? Or do I need to send them away?
Another question. The manual has instructions for removal of the whole suspension assembly. Would I need to do this to get the kingpin assembly out? Anyone's past experience would be very useful.
Last question - is there anything else on the front suspension that should routinely be changed out whilst it is in bits?
Message for Dave Russell - finished the half shaft oil seal job yesterday - took it for a run and no leak!! [well, not from that part anyway!!] Tks for your help as always.
Mike
Mike
