Kingpin Bushings
MY66AH
Going to replace the Kingpin bushings on my 66 Sprite. Is it very difficult? Words of wisdom? Thanks in advance.
nomad
Send it to Peter C who I believe does them. Its not an easy job and they need to be reamed to size after they are installed. I've done one set myself and hand scaped the bearings to fit. Long winter!:p
Kurt.
Jim_Gruber
Let me post a link to tonorrow that breaks it down step by step. I've posted it but tell us your symptoms. In taking the front end apart a Sawzall us your friend.
Jim_Gruber
Here is a Step by Step to taking the Front Suspension Apart and Rebuilding. A handy reference that takes it step by step. Helper bolts which are around 6" long threaded 5/16" rod IIRC will aid in putting everything back together to compress the spring. Tighten the two bolts until you get the spring compressed far enough to get the other two bolts started, remove the helper bolts and then tighten all four evenly. Works slick and is safer than spring compressor and other type of things people suggest. Good luck and ask questions when you can't get things to come apart.
sim
hi Just did mine but peter will not do drum brakes king pin bushings.
Also the ones on my 58 were still good . the big problem were fulcrum pins and wish bones area. Got new wish bones spindles and fulcrum pins. As a result I ended up with 2 extra fulcrum pins and a set of bushing upper and lower. they are now for sale. PM me if interested.
Jim_Gruber
Follow the link I sent for a step by step but you will need a major suspension kit for all of the parts and pieces you need. If you are lucky fulcrum pins can be unscrewed if you can get the locking pin out. My experience after doing this three times on the rusted mess I've is Sawzall needed to carefully slice bolts that attach wishbone to body mounting points. Sawzall also needed to cut fulcrum pin as the locking pin will be rusted in place. At that point the kingpin fall out, clean up threads in wishbone and see how tight the fulcrum pin fits in wishbone.if there is any movement fore/aft metal bushings in wishbone are worn and need rebushing. Apple Hydraulics will rebush. Or with lower prices these days source new wishbones.
After engine rebuild front end is second most expensive part of repatriation to do correctly. Once you get this on the bench and start to take apart the mysteries and questions about Spridget front suspensions will suddenly become clear.
Jim_Gruber
PS you will still new Peter C to ream kingpin bushings. He turned mine around in a day or two and back to me for a very reasonable cost.
Rut
If you have drum brakes and you're rebuilding your front end, now is the time to upgrade to discs!
Rut
Jim_Gruber
That's what I've done with Bugsy. There is a parts car out there from someone on this list that can provide you with disc brakes. I've got new calipers on order that will complete the front subassembly, got to paint them Red of course, along with a sway bar, major suspension kit, rebushed A Arms. Will top that off with 4 of Peter C's shocks and I know Bugsy will handle right.
sim
Rut
I do have drum brakes but last year I bought a new master cylinder. this year i bought new swivel pin kits, new springs, both standard and 340lbs per inch. Will be testing them to see which ones work best for me. Also replaced the wishbones which are drilled and braced for a sway bar. Which I will have soon. I am use to the poor performance of the drum brakes and drive with that in mind. I would like discs but that is now a year or 2 off. Now I am working on rear suspension so I can get the car to go straight in stead of crabing.
Thanks
rod
sim
first thing to do is to get 2 4 inch bolts high grade. to uses as slave bolts to remover the springs. You may have to thread them all the way. Take the wheels off and then remove the back plate do not need to remove the line to the brake cylinder. Just tie it up to keep pressure off the line. Now look at the spring pan. held on with 4 bolts. Remove one and install a slave bolt. Run the nut all the way down. Now remove the bolt on the diagonal position and install the other slave bolt. now remove the 2 other bolts and back off your slave bolts. This will lower the spring. The rest is easy Just do not mix up the position of the tinioun that fits to the steering arm.
MY66AH
MY66AH
Why would a complete NOS front end kit need the bushings "reamed"? The new bushings fit the new king pins just fine.
Rut
The process of pressing out the old bushings and pressing in the new can and usually does reduce the inside diameter of the new bushings. The kingpin to bushing fit needs to be within 'spec' in order to keep them from seizing on the kingpins. If yours fit properly then you are lucky indeed, but if the front end starts to lock up you get to do it over.
Rut
sim
Rut
I tested the fit of new kingpins with old bushings and the fit was fine. I do not know what the spec are but it felt just fine
Rut
Rod,
it's not unusual for the old bushings to fit a new kingpin. Mine fit well on my Bugeye, but the kingpins were discolored (blueish) from friction heat and it didn't cost much to do it right. I wanted my front end rebuild to outlast me, in fact that's the way I'm treating my entire restoration.
Rut
G Kingpin bushings installed for $80? Spridgets 6
kennypinkerton MGB Kingpin bushing reamer MG 0
F Video showing oil pump and Kingpin bushing repacement on BJ8 Austin Healey 3
M Those cork washers on either side of the kingpin... Spridgets 9
SilentUnicorn MGB mgb kingpin reamer MG 6
richberman BPNorthwest kingpin/bushing kit Austin Healey 0
Jim_Gruber Kingpin and Suspension Rebushing Spridgets 1
Dadandson 74 Midget Kingpin to bushing clearance Spridgets 7
OZ_BN1 Kingpin repair kit Austin Healey 8
Stewart Kingpin Q? MG 10
D Kingpin assembly MG 9
L Kingpin Reamer Austin Healey 17
X Kingpin Up-date MG 6
X Kingpin Bushes MG 12
mbrooks Kingpin rebush Austin Healey 5
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
KVH General Tech HS6 Carburetor Bushings Triumph 10
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
R TR6 Lower A-arm trunnion bushings Triumph 18
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
Upland SuperPro trunnion bushings Spridgets 0
R TR2/3/3A Upper Wishbone Bushings Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
tahoe healey Sway Bar Bushings Austin Healey 3
Gliderman8 TR6 Corona boredom relief - Steering Wheel Bushings Triumph 6
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
S TR2/3/3A Clutch cross shaft bushings? Triumph 5
S TR2/3/3A lube for upper A bushings Triumph 2
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
D TR2/3/3A steering column bushings Triumph 8
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
mt10flyer TR2/3/3A poly bushings - upper wishbone Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
S TR6 steering column bushings Triumph 5
N Top link offset bushings?? Spridgets 6
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
B TR2/3/3A Inner wishbone bushings Triumph 5
B TR2/3/3A What do you do lubing polyurethane bushings? Triumph 7
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
Got_All_4 TR2/3/3A Super pro bushings Triumph 2
