Don Elliott
My neighbour has a lathe with a 10" diameter faceplate. He set up the overdrive on the lathe and drove the input shaft with the jaws on the faceplate. He made a plate to keep the oil in the overdrive from leaking out and none spilled or splashed out. The lathe had enough power to do the test and we could manually "click on" the overdrive by simply pushing down on the lever arm on the right side on the casing. We could hear and see the output shaft change speeds up and down as we "switched" the overdrive on or off
