BryanC said:Julian,
If it matters to you, order a Heritage Certificate from the British Heritage Motor Centre
https://www.heritage-motor-centre.co.uk/shop/heritage-certificates/index.html
The certificate will tell you what came on the car as it left the factory including (I believe) engine number, gearbox number, options like OD, wheels ,etc.
The certificate might be cool even if the originality of the OD doesn't matter to you.
Bryan
Bugeye58 said:Can you even <u>get</u> a certificate for a CKD car?
Jeff
As almost any Corvette restorer can tell you, it's not that hard to change the numbers anyway.TheSearcherMan said:I was able to get a NOS block, and they are not stamped. So, I guess the number do match, right?
Easiest, IMO, would be to find a top cover casting that is already drilled & tapped for them. For a J-type there is only one switch, the 2nd switch is to enable operation in 2nd gear for the A-type. But if you can't source a casting that is already drilled & tapped, you'll have to drill & tap your own. Not hard at all, but you'll need to strip at least the 3/4 shift shaft out (I'd do all of them) and find a copy of that oddball metric tap.2wrench said:Do not know what to do with the interrupter
switches.
2wrench said:...Do not know what to do with the interrupter switches [snip] I might have been inclined
to store my original tranny; buy and install the
new, at the kinds of money you mention...
Geo Hahn said:you would still need to open/rebuild your 'box with the longer mainshaft.
Nope, you've got it right. I'm sure Geo knows that ...Adrio said:It may be my bad memory but I seem to recall the O/D main shaft was the shorter one and the regular non-O/D shaft was the longer one. Some one tell me if I have to reprogram my brains memory chip please.
Springs on a J-type are way inside the unit, not between the unit & the adapter plate like on the A-type.glemon said:I have not had this newer type O/D apart before, the older ones I am familiar with have a bunch of springs between the O/D and the box, don't see any on this one, are they missing or are they not supposed to be there?
Goes into the top cover of the tranny, where it's plunger rides on the top of the 3/4 shift fork. Geo posted an excellent photo earlier in this thread, so page back and have a look.glemon said:by Gearswitch I mean the switch that only allows the O/D to be engaged in 3rd and 4th, it screws onto the tranny or tranny linkage, I forget which.
