TR6 installing new choke cable
edkap2002
Looking for advice and instructions for installing choke cable on a 72 TR6. Any advice greatly appreciated. Thanks as always
Do you know if the knob is like the original version which is removable or like some of the aftermarket versions where the knob is fixed ?
That's going to determine as to whether the new cable is inserted in the dash from the front or from behind the dash.
thanks as always for responding. I will check the new part and get right back!
sorry for the two month long delay..the knob is faxed to the cable...from BPNW...doesnt come off as the original...still havent changed it out...still using closepin! :smile:
No Problem..just slide the nut that belongs on the back side of the dash onto the end of the cable that will attach to the carbs after you put the cable into the dash, but before you feed the cable thru the fire wall.
Run the nut up the threads a bit, but wait to make the final adjustment until you get the carbs hooked up to the cable.
got it1...thanks as always
