I spotted a 1975 Spitfire in the local craiglist. Wasn't running but had been in garage. 1000.00 or OBO. It was so close to home and after talking to the gal, I went and looked at it.
It is really rust free. The underneath is clean, it appears to have original chocolate brown paint. The battery compartment had one corner corroded out and there was a pile of white powder on the floor board. But no damage there. Soft top had cloudy windows and one cracked. It has a weber DCOE 40 on it. The rear spring has been replaced by one from a local outfit called Benz Springs. It has an overdrive.
Long story short, I made her a considerably lower offer and she agreed.
I put some fuel in it and got it to run. Took it around the block and the overdrive worked. Couldn't believe the clutch and brakes worked but they did. However while driving it home it started to over heat and we towed it the rest of the way.
It has this odd noise like maybe the fan clutch is going out. Also the alternator is not charging. It has a lucas unit. Any common aliments, I should check for here?
I read that the Weber should be a 45 if it is a single. Is this correct? Will this 40 work or should I replace it will a dual Stromberg or SU setup?
She also has a Manta that is setting uncovered in a garage collecting dust. These were her father in laws cars and he was killed in a car accident and they have been selling off his cars. She is talking about getting this Manta running and then selling it. Very cool looking, but I must say I don't know anything about them.
Thought I would clean this Spit up and play with it this summer and perhaps find it a new home. If it gets good fuel mileage, I may keep it. It cool setting so close to the road.
