Illuminating gauges with Electroluminescent tape
Pix!
MKIII-style fuel gauge without windows.
The area where the tape will have to go.
The spatial situation.
The unsuccessful CV2-1148 test.
Alligator clips work but are kinda bulky.
Hi Tom,
Maybe now you can appreciate why I gave up and just bought four tapes with leads already attached and just cut each to fit. At $8 per tape + inverter, it's almost less expensive too. :smile:
Best of luck!
Dan
Do you have to remove the gauges from the car, or can they be done in situ?
You'd definitely need to remove the gauges. Otherwise, I don't know how you would drill the required hole in the speedometer and tachometer housings, or remove the blue plastic ring in the fuel and combination gauges.
Dan
