kodanja said:I want two of each
1 to drive!
1 to keep in my garage!
I can only dream of having a garage the size of yours! /bcforum/images/%%GRAEMLIN_URL%%/bow.gif
1 to drive!
angelfj said:Maybe my imagination, but there seems to be a definite LBC pecking order.
toysrrus said:Like the majority here; I too had a few "MGs": 2-TDs / 1-TF / 2-midgets / 1-Bee: All of which were a Ton of Fun:
Compared to the TR3s / TR4s & TR6s I`ve had; "In My Opinion"; There is No Comparison in reliability, performance, Crowd pleasers & re-sale value, etc:
Regards, Russ /bcforum/images/%%GRAEMLIN_URL%%/banana.gif
IanF said:jdubois said:Hmm, that's a Bosche D-Jet system, right? With that having to turn the key on/off sequence, sounds like maybe a bad time switch for the fuel pump? If the car runs fine when warmed up, it's gotta be that or the CSI as you mentioned, or the AAV, right? Unlike the K-Jet systems (which make me tear my hair out), I don't think there's much else to the cold-start circuit on those things.
It could be the fuel pump. It started making some noise earlier this year. We bought an aftermarket EFI pump from Summit that I plan to make work. The $400 folks want for the correct Bosch pump is just insane... if it was a visible part, I could see it... but it's just a fuel pump... I'll probably pull the CSI in the spring and see what I can do with it.
The AAV works as I can notice a drop in idle RPM as the engine warms up... actually, the only way I know it's warm as the temp gauge still doesn't work...
Still have a lot to do to Baldrick over the Winter, although not as much as last Winter...
