Dear fellow BCF members: I hesitate to write this note after all your good suggestions on how I can eliminate vapor lock. But to bother you again, I’ve come to the conclusion that my problem with stalling may not be vapor lock at all. When this happened a couple times in the past year, it was a hot (90+ F) day and I was in stop n go traffic. The temperature rose to 230 F one time, and about 200 F the other. Both float bowls were empty when it cooled down (off the road), so when I filled them, it started right up and ran me home with the coolant below 190 F.
This time, however, the car lost power driving 50 mph on a relatively cool day (75 F) and the coolant temperature never went over 185 F. Again both float bowls were empty. So I jumped to a conclusion it was fuel vaporization like before. BUT, now I’m thinking it is a deficiency in fuel delivery. I have a new, mechanical pump. But maybe at speed it is not keeping up with fuel consumption. I also have a new fuel tank, which was 3/4 full. So I’m thinking that maybe a spec of dirt got in the fuel and fouled the first float bowl needle valve. I’ll check that out (because it’s easy). I don’t have a fuel filter, and shame on me, I should (and will … in the fuel pump suction from the tank).
You don’t need to waste anymore time on me, but if you will, are there other ideas? I haven’t heard that mechanical fuel pumps on TR3s chronically can’t keep up with fuel demand at speed.
Thank you,
Don
