HOW do I get this thing apart?
People tend not to take me seriously Doc. I'm throwing supper together, regrouping, and after olwhatshisname leaves again, I'll go back out there. He thinks I'm stupid and don't know anything also when it comes to cars.
I'll tackle it after supper and a cuppa.
'k... I'll keep checkin' back. This ain't gonna get ya.
Pull the dust cap off. There is a hole in the hub where you have to drop a pair of thin needle nose pliers through to pull the cotter pin out. Also, you will need those pliers to straighten the pin before pulling it out.
Unscrew the castle nut (1 1/8"??) Then pull the rotor and splined hub off the swivel axle!!
Then you can separate the hub from the rotor.
Janel - (& what I'm about to say, I'm saying in a loving, positive way)....before you take anything else apart, go buy a Bentley manual & read the procedure
...you've taken it apart in the wrong order & now its going to be harder than if you did it correctly the first time
...before you can go any farther, you've got to get that stub axle off the hub - take the "spinner" off & then remove the dust cap that's under it...align the hole in the hub with the cotter pin way down inside under the dust cap & remove the cotter pin....loosen & remove the castle nut holding the hub to the stub axle - remove the stub axle from the rear...be real careful you don't loose anything...there's washers & shims inside it that you'll need to rebuild it
....then you can take the rotor off the hub...you'll need an air wrench & an open-end wrench as the whole bolt/nut will turn as it loosens
...remember: Bently manual (you'll need the green one)
Tony, and I'm saying this in the most loving, postive way I can...
(because I'm ready to bite the head off a rattlesnake)
I HAVEN'T taken it apart yet. I can't GET it apart.
I had the bloody Bentley (the GREEN one) in front of me all day. And the Haynes. And the VB and Moss catalogs with exploded pictures.
I've had the spinner off. And the 4 nuts on each assembly. I can't get beyond that. The freaking dust cover won't come out/off so I can get to the hub nut and cotter pin.
Okay - I'm going to give away a factory secret....go to the rear of the engine - passenger side...there's 1 head stud that has a nut that's about 3" long...the end of the bolt that's not attached to the head stud has a small threaded hole in it....that small threaded hole fits the stud on the dust cap....
What I've done is take an extra head stud & welded a flat piece of metal on the end that goes into the head...then, I screwed that long bolt down on it & - VOILA - dust cap wrench!
If you can't find the bolt off Binabox - the one on Emma will work...just grab one of your loose head studs & thread the long bolt onto it
This too shall pass...
ViseGrips!
Doc - you posted before I got finished...& I must've owned one of your ex-MG's because I've come across the vise grip trick!
I got the bugger off. Put it on the floor, stood on the rotor and got really p!ssed off and yanked.
Bad Karma.... I said "in a pinch!" and I've rethreaded any one of those I'd buggered.... and have a tool for the task as well. Just hard to pass it thru the innernet, y'see. /ubbthreads/images/graemlins/jester.gif
That works also - what'd you use to pull it with? Did you damage the threads on the stud?
Now, align the end of the cotter pin with the hole in the hub - straighten the open ends of the cotter & use a cotter pin puller to pull it through the hole in the hub
I don't need no stinkin' vise grips.
/ubbthreads/images/graemlins/laugh.gif
WOOOHOOO!!!!!!!!!!
"Pittsburgh Forge"!!!
Of course I didn't damage the threads.
I have no idea what a cotter pin puller is, but I have my trusty needle-nosed pliers.
Tony, Doc, hang loose, I got this bugger beat!
Oh, jeez!!!!!!!!!!!!!!!!!!!
Told ya so.
[ QUOTE ]
[/ QUOTE ]
Them "snipe-nosed gits" (needle nosed pliers) will work to straighten the pin and "finesse" it outta the hole. Easier than a Chinese wood block puzzle, fer sure.
Okay - as you loosen & remove the castle nut....be careful...don't loose the shims that are back there...& remember the order in which everything comes off...you'll need those shims again later when you put it back together
Got the pin out, the nuts and washers are off.
That's a big dang nut in there.
Shouldn't be too tight tho. If you've no socket large enuff, the PLIERS may work... and use that prybar as a leverage tool between the handles.
mezy A thing of beauty Other British Cars 3
Hamish Racing 1963 original racing film British cars doing their thing Racing 0
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
S TR2/3/3A What's a little thing that made a huge difference in your vehicle? Triumph 37
S TR4/4A What is this thing? Triumph 3
L TR6 Is there any such thing for a TR6 ? Triumph 9
Pythias For Sale The Red Thing... Make Offer.. Spridgets Classified 0
60TR3A What's The Weirdest Thing Anyone Ever Said or Asked You About Your Car? Austin Healey 28
J Funniest thing you found working on your car Austin Healey 32
AN5Sprite "Does this thing have airbags?" Spridgets 22
DrEntropy MGB A little thing MG 4
ObiRichKanobi These cars do the damnedest thing... Triumph 12
R Does this thing come off? Spridgets 5
Boink Tonneau Covers - that flappy thing - what is it? Spridgets 17
Mickey Richaud Just the Thing... Other British Cars 21
lbc_newbie Closest thing to a West Coast deal!! Spridgets 4
TR6oldtimer The thing I forgot to do Triumph 2
Brosky TR8 Visors NLA, so I did the next best thing Restoration & Tools 2
BobbyD TRafficator Signal LED Buzzer Thing Triumph 7
mikecyc72usa It's a good thing, right? MG 3
tinman58 Second thing to check Triumph 14
1 What is this thing? MG 10
G One thing after another MG 30
TR4A_IRS TR4/4A TR4 Hardtop - Is there such a thing? Triumph 7
T Post-War Other No such thing as a 1 hour job on a Herald Triumph 8
pjsmetana Fuel Filter, anyone got a part # for this thing? Triumph 11
T What do you think - good thing I pulled them? Triumph 6
T Wedge TR7/8 doing it's thing in this clip Triumph 3
T I think I did a dumb thing Spridgets 14
C turn signal bulb type thing Spridgets 4
P weird thing with midget clutch pedal Spridgets 3
smaceng Help me find the steering thing! Spridgets 7
jdubois Finally, this thing is starting to run ok! Triumph 7
D Ready to shoot the thing II--an Latest Spridgets 7
D Ready to shoot the thing! Long story please help! Spridgets 10
T It's a small thing, but WOW. Triumph 25
jhorton3 If It's Not One Thing It's Another Spridgets 3
jlaird This may be just the thing for someone. Triumph 1
regularman The bad thing about having a high rear gear Spridgets 13
G What is this thing !?!?!?!?!?!? Spridgets 6
Sarastro Was this a smart thing to do? Other Cars 18
regularman Still trying to figure this overheating thing out. Spridgets 35
Tinkerman Did a REAL Dumb Thing!!!! Triumph 7
healeyboz Is there such a thing as Spridgets 4
T Hap, what is that thing...? MG 14
vping Last thing on my OD problems. MG 5
wkilleffer What causes heat soak, and is it a bad thing? MG 16
MTribe Is sound deadening on floor pans a good thing? Triumph 24
