Almost correct
Yes the diff assy just comes out. It is heavy.
Sounds like I can just pull the diff out forward of the read end assembly, remove the broken bit, check the spider gears for wobble and slide it back in if all is good.... correct?
Driveshaft is unbolted but remains in place. It needs to be lifted out of the way. do not take it out It is almost impossible to put back in with the engine in place. There are tricks to do this but don't worry now.
Hi Guest!
