the ebay guy seem to have good feedback and I suppose if he has an axle and no use for it, get whatever he can. I don't really have any experience on Sprite axles but the weak point is where the splines start. Every other axle I have broken ('46 Chevy multiples) it was at that point. One other fault with a used axle could be not knowing which side it came from. Over time, axles tend to take a certain set or twist from always under load in the same direction. That could cause some problems if you put it on the other side.
