TR3driver
Great Pumpkin - R.I.P
Nope, turning the dome won't help with the "30 degree" problem. The sweep is fixed by the position of the crank pin on the big gear and the wheel diameter in the wheelboxes. Turning the dome can only change where the motor stops within the sweep when the switch is turned off.
Might be wrong parts, but my guess would be something loose, like maybe one of the tubes isn't attached to the wheelbox; or perhaps the big gear is damaged. And IMO you should definitely address that problem first, before playing with the dome.
