MGB Heater / Air box drain
Boggsy64
I was looking for the drain in the air box, located behind the dashboard, because I thought there must be one, but I could not find one no matter how hard I looked. I looked on line and found some great photos from a guy in UK showing where it should be (attached photos). I finally found the problem, mine was completely full of sand and dust, like concrete, from apparently being driven in Arizona. The dust had completely filled the pipe and opening so it looked like one had never existed! Using coat hangers and drill bits now to clean it out. Good lesson and I will work to keep this open at all times.
PAUL161
The duck tail will collect dirt also if the car is in dusty conditions and where small tree foliage can fall into the air vent, once it does, the tube will clog up again. I removed the duct tail for a clean passage in the tube. The duck tail is only needed if it's a concurs car and a judge want's to crawl underneath. :highly_amused: PJ
Boggsy64
Boggsy64
During my investigation online I found a lot of debate about keeping the bob or duck tail on the end or taking it off. Some said it was necessary to keep out fumes. Mine is coming off as well, I would rather have a free flow than take a chance!
Platinum
I use a piece of bicycle innertube at the end of a hose for the "ducktail."
Boggsy64
Boggsy64
Once I cleaned out the "concrete" from the drain it worked great. Several large glasses of water poured through a funnel went right on out. No wonder the floor was so soaked when I drove all day in a rainstorm!
PAUL161
Agreed, water will run out if the tube is clean. But if the car is exposed to dust, dirt and debris from trees, the tube can clog with the bulb/duck tail in place and cause problems later. I never heard of anyone smelling fumes coming from the heater because the duck tail was removed. If that were the case, there are other problems present. PJ
WillR
I wish I could have my problems sorted out to details like this. It would make no difference with or with out it in my mess. My exhaust manifold pours fumes. you climb out of the car smelling like you have been on a snowmobile for a day. Then again it probably wouldn't hurt to clear that drain out
drooartz
I hear you -- but then, my car is currently in boxes on the shelf so I'm a long way from fixing the little details. :smile:
Boggsy64
Boggsy64
Drew, you would be proud. You posted a pic some time ago with the "bankers boxes" neatly stacked in your garage. I went to Walmart and bought a pack of 10 for $13 and now I have my own collection of parts in boxes! Really helps with the space...great idea!
drooartz
Those boxes are cheap and they work -- or at least they look neater on the shelf! We'll see how organized I really am when it comes time to start putting parts back on the car. :smile:
Boggsy64
Boggsy64
I know what you mean, I didn't waste much time filling them....believe I will find out that I should have spent more time documenting!!
WillR
Im a step behind both of you. Mine is still parked across country and Im just starting to work with a transport company. But believe you me, during my first ever open motor that air box drain is getting a good scrubbing!:encouragement:
Boggsy64
Boggsy64
Will, I remember your engine giving out on you, did you find a low cost transporter? I found several at around $850 from AZ to NC. And good luck on the move then the fun really begins!
WillR
Im frustrated a bit going through different companies, cheapest i can find is 1300 with one named 5 diamond auto. I just cant seem to find many reviews on them. the price jumps up from there, bummer as it has taken this long just to get 1300 saved up. I live in a bit of a rural place in south east idaho so its a bit more to get it here.
drooartz
Take a look at uship.com as well. It's a brokerage site where you can bid out your job. Used it to get a motorcycle from TN to UT a couple years ago, worked well. You'll get large companies bidding as well as guy-with-a-truck.
WillR
Thanks drew ill look them up now. Im a fan of little guys and small business for the most part but cash talks and i just want to get started.
Boggsy64
Boggsy64
Will I am looking at a job in Jerome, ID. I currently live in North Carolina and Jerome looks fantastic for scenery. You will have to let me know what to expect for year around weather.. I am currently looking for a new (new to me) truck and was wondering if I should consider 4WD if I moved to ID. I don't need it here but think there are many off road situations there? The 4WD would be a good contrast to a LBC!
WillR
Its a lot less mild then the north east, It will snow and people will some how forget how to drive overnight when it does. This year i only remember one white out on the road and that only lasted about a half hr. The snow is drier then Im used to making it easier to get through. It can get cold. Wide open spaces makes for wind. Im a bit north east of where your looking in a place called Rexburg. We lovingly call It Iceburg. Unless you are going off the main roads 4WD wouldn't be needed remembering that it does not make you invincible it just gets you through where 2WD may not. Though you go through with a heavier weight helping those SUV racing around snow plows at full highway speeds lose control. Makes me laugh. If you remember the tires i put on my B were snow and ice and I tried a cross country. Admittedly that did not end well.:beaten: Though there is a lot of fun dirt roads that 4WD makes accessible in both winter and summer. It is very pretty to get lost in. Different then the east, i had to learn to see the beauty in it. I made it around fine last time I was out here in studded tires on a mid 90s civic hatchback. Stuck to the streets better then most... i might have taken it in to the sage brush once or twice to show I could keep up with the trucks out here. Its like the greasers vs the jocks with the trucks and the small cars. little guys get hated on. Even had it in the air side ways at 50mph. Im sold on those things. All in all Im saying take the job. MOve to the mountain states. When you get here and our LBCs are running well we can shoot down to Utah and have a LBC canyon weekend
drooartz
I made it around fine last time I was out here in studded tires on a mid 90s civic hatchback. [... ] When you get here and our LBCs are running well we can shoot down to Utah and have a LBC canyon weekend
I've spent most of my time in Utah driving small FWD hatchbacks, with snow tires for winter use. Hard to beat -- though I admit I did just buy a Jeep, more because it's fun. :smile:
And if you do make it down to UT for some canyon running, let me know. I'll join in with whatever I have running at the time.
WillR
Great mpg and a whole lot of room in those. You can have a lot more fun in a jeep just cant afford one yet. first a well running lbc and a cruiser small gas sipper as i have now sold mine then ill look for a fun jeep. well theres the rifles i "need" the camping gear im way behind on acquiring. The list gets bigger every day. Have no doubt I will be wanting to met up, i still need to see a bug eye up close
I TR6 TR6 Heater box /air distrbution cable help Triumph 7
F Heater pipe and air duct routing BT7 Austin Healey 3
Rut General MG Heater/air control MG 0
P BUGEYE HEATER FRESH AIR VALVE??? Spridgets 14
I Bugeye heater air duct length? Spridgets 3
losmorob Heater/fresh air vent on an early '67 Spridgets 1
J BJ8 air from heater cable routing? Austin Healey 4
58Custom 1969 Heater air inlet behind grill- pix? Spridgets 37
Jim_Gruber Heater Air/Valve Control Cable Spridgets 2
G Fresh air hose for heater Spridgets 16
AUSMHLY Fresh air hose clamp, heater blower ground Austin Healey 5
Kurtis Sprite heater/fan air duct question Spridgets 10
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R TR6 Heater control bezels TR6 Triumph 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
R TR6 Heater box Triumph 6
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
D Heater knob removal Spridgets 6
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye heater cable Spridgets 12
E austin van heater removal Other British Cars 0
Lin Heater water valve question Spridgets 2
T Bug Eye Heater Switch Help Spridgets 2
T Heater Door Spring Austin Healey 1
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
H BJ8 Heater Valve/Control Tap Austin Healey 3
jlaird MGB Heater MG 5
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
6 Smith heater rebuild Austin Healey 8
Healey Nut Heater Box Installation Austin Healey 4
CJD TR2/3/3A Heater Delete Triumph 15
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
F TR6 Heater Triumph 7
C Water flow in heater? Austin Healey 5
C Heater knobs won’t stay on... Austin Healey 4
Lutz Kramer Heater Control Valve function Austin Healey 2
S Heater and fan control replacement - any advice? Austin Healey 9
S Wanted Austin Healey heater assembly Austin Healey Classifieds 1
C TR6 Heater Removal Triumph 2
R BJ7 heater blower vibration Austin Healey 11
wangdango BJ8 heater blower? Austin Healey 4
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
F Heater valve/tap gasket- Install dry? Austin Healey 10
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
