AH.MKII.Restomod
I suggest the Alternator option and the switch to Negative ground (positive Alternator cost more)
this allowed you to increase the engine cooling
I'd suggest a new oil pump and the vane type rather than the geared one. This is because the pumps do wear, the oil pressure drops and the engines are rougher at freeway speeds. The engine is nicer higher revs with a perfect pump.
Most of the big ones are covered, but would replace anything with rubber e.g. wiring, damper, bushings, and so on. Just not worth taking the risk since your putting in the effort and time bringing such a cool car back...
Which do you recommend? Does moss carry the upgrade?
So even though my damper is in good shape and the rubber is good you recommend that i purchase a newer harmonic balancer? THey arent cheap so I want to make sure it is worth it.
They can look fine, but I know from experience they can come apart and take your cooling system with it. They can be relaminated, but the new ones are much better.So even though my damper is in good shape and the rubber is good you recommend that i purchase a newer harmonic balancer? THey arent cheap so I want to make sure it is worth it.
Oil Cooler?? Yes
Fuel pump upgrade?? An electronic-switched SU is fine.
alternator conversion?? Yes
Starter upgrade?? Yes
Pos earth converstion?? Yes
Led Lights?? I haven't found any that are acceptable.
Coil upgrade?? Yes
Ignition upgrade?? Yes
Cool thread, Restomod. I love the reuse of old parts, doing what you can yourself and having the big stuff done by the pro's (frame). Good luck and success to you.
Chris...
Oil Cooler: Mine is from Denis Welch, ACC124 & CACC1272. You will need the spin-on oil filter adapter from DW or Moss (635-840).Which parts/brands do you recommend for these upgrades?
