jlaird
Lets do it the easy way guys.
It is 180 out, no question if you reverse the wires and it is ok.
Pull the Dizzy. Look down inside for the slot.
Use a long bolt to thread into the center of the gear thingee.
When you pull it out turn it 180 and put it back. It will need to go in to start one tooth counter clockwise than 180 so that it ends up 180 from the orginal slot you made note of. Write it down.
No TDC will be required if you note the position you have at present and turn it 180. Check with a flash light down the hole.
Be very careful and it might take a total of 15 min for the whole process.
