Have radiator, have coolant, have speed=FUN
sabot
:banana:Got the radiator in, fans work fine, and after putting some gas in :wall:, we got speed!
At least 1 of my 4 Triumph's runs.
Thanks for the help guys.
Tom
Ain't life grand? :thumbsup:
When do you get to "play" with it for real? :driving:
That would be after the power steering gets fixed.
So what am I looking for to figure out why it's leaking? Any common problems I
should look for?
thanks Tom
should look for?
thanks Tom
I would start with the hoses on the rack. If the engine runs, start it up and have someone turn the wheel back and forth while you look for the leaks. If it is the hoses, then a local hydraulic shop should be able to make new ones.
Tom -
Lucas fluid with stop leak has gotten pretty good reviews. You might give that a try before tearing into anything.
