:banana:Got the radiator in, fans work fine, and after putting some gas in , we got speed!
At least 1 of my 4 Triumph's runs.
Thanks for the help guys.
Tom
That would be after the power steering gets fixed.
So what am I looking for to figure out why it's leaking? Any common problems I
should look for?
thanks Tom
should look for?
thanks Tom
I would start with the hoses on the rack. If the engine runs, start it up and have someone turn the wheel back and forth while you look for the leaks. If it is the hoses, then a local hydraulic shop should be able to make new ones.
