Gonna try and get my Six [ Amos] running again
T
Tinster
Feels like it's time to get my bucket of bolts, old 1969 Triumph TR6 out of moth balls and back running in the street. A five month sleep due to extreme summer tropics heat and monsoon rains. I wonder how difficult it will be get Amos going again? He was running pretty good five months ago.
Dale (Tinster)
martx-5
If the battery is charged up, a turn of the key should get it fired right up. Five months of sleep is not that long.
justin_mercier
When I started up my TR6 it had been sitting for 3 years. I had to replace the starter because it was bad, but after that, with a charged battery, I just turned the key and it fired up. It ran rough for a bit because of old gas in the lines, but once it got to the good stuff and warmed up, it smoothed right out.
smaceng
How about the battery charge and additive in the gas tank? Check the fluids, and that the fan belt is tight. Air the tires and go! After you start, check that the battery is charging.
Scott in CA
TR4
My 4 sits for 4-5 months every year through the winter and has fired right up on the first warm dry spring day for the past 8 years that I have owned it.
T
Tinster
added 1/2 tank of 93 octane plus 6 ounces of SeaFoam.
"Huston- We have primary ignition under full choke at fairly steady 1200 RPMs, but no lift-off today.Cannot full throttle; will hit 3000. Engine dies without full choke. Engine shut by control tower down while holding 1200 RPMs.
Tomorrow will clean points and vacuum gauge set the timing.
I think the project is a "Green Light" and the car needs to be in the street for an "Italian" tune up. No slur intended. Old school guy.
71MKIV
make sure your fuel filter hasn't sludged on you. full choke is a sign of poor fuel flow.
T
Tinster
Thanks a bunch Steve!!
I didn't think of that one. Easy enough to check
and I've got spares of almost every component of the car!
Thanks again.
I was surprised how easily the car started, given it's
dismal history.
Dale (Tinster)
ekamm
Ethanol i.e. bad gas ,put as much good gas in as you can and burn it out before refilling the entire tank with good gas.
70herald
Dale, I ignored the Herald for nearly a year, while dealing with more urgent problems (moving, work, kids.....)
After a year, I hooked up the battery, and it turned right over, just didn't start. Finally the brain turned on, and I noticed that the gas tank was empty.
A quick trip to the gas station and it started right up on the first try. Just make sure you have the normal stuff, coolant, oil, gas, and you should be just fine.
When you take it out for the first drive just take it easy, make sure that the brakes are working and have a great time.
71MKIV
Dale, I forget which carbs you have in Amos, if they are the SU's, make sure the gas hasn't gotten the needles stuck. Sitting overnight with fresh gas might even have freed them up a bit.
Keep going!
Dale (Tinster)
Dale, you're being modest...you have a COMPLETE car worth of spares! :laugh: LOL
I look forward to hearing that you're out cruising in the very near future! :driving:
angelfj1
"Dale, you're being modest...you have a COMPLETE car worth of spares! laugh LOL"
Yes - and some how he has managed to cram all of it into the boot! :yesnod:
GeeBee1
Watch it, Dale is actually back writing about Amos.
Next Kenny will ask what' fer dinner, Doc wil fin Scooter and smoke wil b free.
GL Dale,
Pat
GL Dale,
Pat
Thus order was restored to the Universe and they lived happily ever after!!
T
Tinster
Just visiting and saying Howdy Pat.
Not gonna be a regular.
I learned my lesson 2 years ago that I
know almost nothing about the TR6 auto and
it's best I render no opinions and keep my mouth shut.
I got new license tags and emmissions stickers for Amos this morning.
Hopefully, a very detailed tuned up and replacment of the ignition system and I'll be in the street again.
Thanks for thing of me.
dale (Tinster)
GeeBee1
Dale
Some of us miss your triumphs and tribulations.
At the very least keep us posted about los tres gatos quests.
Pat
T
Tinster
Hi Pat!!
Point made in spades this afternoon.
Note to self: After putting the car away for 5 months and trying to bring it back to life, let's us not forget one important item.
After cleaning and adjusting dizzy points, new gas plus Sea Foam, the engine will be be much more willing to ignite if the dizzy rotor is also re-installed.
Timing set at 10* advance ,Engine sitting at 800 rmp idle, some choke required. Rright now, gonna let it burn for 1/2 hour to wash out any gasoline varnish that might have developed.
just sayin'
dale (tinster)
GeeBee1
sounds good, you will get El Gato out in no time :thumbsup:
Pat
71MKIV
BTDT.
"why won't this miserable thing start"
"oh"
:rolleyes:
I had an even worse one. First got Jehu on the road after 4 years. Had it out for it's first test run, running great, all of a sudden it quits. played with choke,key, starting to slow. All of a sudden it comes back with a POW.
Next morning on way for inspection, it dies again, this time I drift to a stop.
fiddle, play. dist cap off. play some more, it's acting like it's off time. What the dingdong?
Cap off again, just happen to bump the rotor, and it moved??
hmm, new rotor and the contact on top is burned already. Here the rotor jumped out of it's notch and was pointing where it darn well felt like it.
Retensioned the spring on top of the rotor and haven't had a problem since.
matmire gonna try making some wind wings. Spridgets 13
Rut TR4/4A LBCs, whatcha gonna do? Triumph 11
Rut LBCs, whatcha gonna do? Spridgets 15
S MGB When your breaks off. who ya gonna call......? MG 2
glemon OK who is gonna bite on this one? Triumph 19
tinman58 I'm just gonna....... Triumph 6
longbridgehealey guess I'm gonna paint a target on my 100-6 Austin Healey 14
scubabatdan Your gonna laugh.... Spridgets 12
64rocksprite Gonna have to change my signature... Spridgets 18
2wrench I think I'm gonna go for a repair on my block. Triumph 25
drooartz Engine decision made, gonna be a fun winter! Spridgets 21
floyd I'm gonna need help..... Triumph 8
regularman Gonna start back on the midget Spridgets 12
C it's gonna be 75 today MG 6
A this gonna slow things down a bit. Spridgets 8
jaybird Okay boys, gonna need your help! MG 101
S New Lotus -- You're not gonna like it. Lotus 14
waltesefalcon Spitfire Gonna build me a Spitfire 6. Triumph 7
LastDeadLast Daddy's gonna have FUN TONIGHT!!!!! Triumph 14
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
Lukens TR2/3/3A Randall, let's try this Triumph 4
Basil Lotus and Jags second try Spotted 3
T Victoria British seat recover kits- anyone try them? Restoration & Tools 3
K Anybody Try Exactline blades? Restoration & Tools 4
B TR2/3/3A I'm going to try some lead repair. Can I do this to my doors? Triumph 9
johnrip Wedge TRy crankcase pressure Triumph 5
T TR4/4A Second gear hard to shift into on first try Triumph 10
N What to buy, second try MG 26
M Try to block junk on ebay Triumph 14
Willie_P TR 3/4/6 -try to talk me out of this: [suspension] Triumph 28
Tr3aguy TR2/3/3A Next step to try to start TR3 Triumph 3
lbc_newbie Don't try this in your Spridget!! Spridgets 15
A TR2/3/3A try this again 59 TR3A project photo Triumph 7
jlaird Try this for floor mats. Spridgets 3
Gundy Don't try this at home! Spridgets 112
J 30 years of not starting engine,should I try it? Triumph 26
T Try and rebuild or get a new engine Triumph 8
bthompson Try and top this one! Spridgets 16
B Anyone Try this Camera? Racing 9
M Don't Try This At Home? Spridgets 4
Got_All_4 Having Problems? Try This. Triumph 0
jlaird Try this site Spridgets 4
jlaird Going to try something Spridgets 17
M Let's Try This Again... Free to a Good Home Spridgets 25
Bret Hey look a 911 try'n to look like a 928. Other Cars 4
billspohn Try This with Your MG MG 4
H Should I try it? MG 13
jlaird Try this for a throw away Restoration & Tools 17
PATR8 Wedge TRy to figure this TR7 out Triumph 10
roofman Any one try one of these things? Triumph 5
