Getting cool air into the footwells
Frankenhealey
Anybody have some good ideas apart from power sapping aircon?
Cheers,
Ian
andybj8
Ian
I believe Cape do an uprated fan kit ref kfk2, I believe it uses a 4" inline fan that goes in the duct, you will need to check with Steve, otherwise why not double up and get a modern 12v 4" fan.
andy
Cottontop
Hi Ian,
Before my current mods, I had a duct from the radiator support into each footwell.
Airflow was controlled by a small pull-knob on the outer corner of the dash connected to a butterfly valve.
NOW, I have Air Conditioning with a valved duct that dumps cool air into each footwell.
Tim
AUSMHLY
Tim,
No Demisters?
Heater?
"NOW, I have Air Conditioning with a valved duct that dumps cool air into each footwell."
You installed an actual air conditioning unit?
Must be nice :cooler:
HealeyPassion
Ian, the a/c takes a few hp when on... but I doubt that there is much parasitic loss when it's off. Just a thought.
Cheers,
Steve
Cottontop
Hi Roger,
AUSMHLY said:
No Demisters? Heater? You installed an actual air conditioning unit?
Since I installed the Ford V8 in 1976, I have not had a heater nor demisters (NOR a top, but that's another story....).
Remember, I have a Healey, I have a V8, and I'm in Texas. ALL 3 of those conditions make a heater unnecessary.
Yes, I have installed an actual A/C unit (not just open windows). When you have 300 HP, you can spare a few to be COOL ! It even has a built-in heater, although it'll probably never be used.
It hangs from the cowl webbing, between the back of the instrument panel and the firewall.
AUSMHLY said:
Must be nice
Not finished modding yet, but I'll let you know.
Tim
Patrick67BJ8
Cheers,
Steve
My AC when ON is barely noticeable. The Factory AC and it's York compressor was another story but the rotary fits and operates real smoooooooth. I suppose I could wire the throttle and AC through the OD throttle switch to kick off under full throttle(with a time delay for reconnecting), but the 5 speed took care of that mod. A fast idle solenoid is now needed so I'm reseraching that.
Patrick
dougie
Ian I've ran an air duct directly from my rally vent to the footwell of my vintage racer. The only problem is if I don't cover it while competing in the rain.
Dougie
Michael Oritt
Dougie--
How do you fill those reservoirs?
dougie
Michael - They're not quite as tight as they look. Given the fact I usually overflow my morning coffee (my wife always lets me know) I do pretty good topping off the reservoirs.
Dougie
Frankenhealey
Frankenhealey
Steve,
No room for an A/C compressor under hood so Ive had to rule that out in the past.
Tim, Dougie,
I want to draw cool air into the footwells and exhaust it from there. If I blow cool air into the footwells I'm going to get all the warm air around my face. I like Tim's pictures of the footboxes with the piping so may put a couple of inline 12V fans there and exhaust out of the wing vents.
Thanks for all the sage advice.
Cheers,
Ian
Michael Oritt
"Given the fact I usually overflow my morning coffee (my wife always lets me know)"
Well my wife always lets me know that I can't hit the toilet while standing up and thinks it reasonable that I be required to pee from a sitting position. I tell her she is simply jealous that I have options but that never seems to get much of a laugh.
Cottontop
No matter WHAT you do, you are going to get the footwell air in your face.
Air ALWAYS moves from a source of higher pressure to a place of lower pressure.
Because of the airflow hitting your windsheild and flowing around both sides (and over your hardtop) the fast moving air will create a low pressure area in the cockpit and suck the air out and into the flowing airstream. Think of someone smoking a cigarette in the car ahead of you with the window open a bit. Almost all the smoke is sucked out the window.
Bernoulli's Principle
If you bring or force (fresh) air into your footwells, it will move from that higher pressure area around your feet, up into the lower pressure area around your shoulders and head, to be sucked out the side window openings or top vent.
The ONLY way to keep that from happening would be to TOTALLY seal the side windows (and THAT ain't gonna happen with a Healey) or to construct a cockpit tonneau that ties tightly around your neck. Then you might be able to vent the footwell air out of the side vents and keep it outta' your face.
Sorry Ian, but I don't think that will work. If you duct fresh air into the footwells, I don't think that you'll be able to use even high CFM fans to try to suck it out of the footwell before it has a chance to ascend into the low pressure area around your torso. The footwells are a huge volume to try to evacuate with fans.
IF you are able to successfully evacuate the air from the footwells, the footwells then become a low pressure area, probably lower than the upper cockpit and I'm sure that the air will move down from the cockpit faster than it will come in through the fresh air footwell vents. That might keep the footwell air out of your face, but if that happens, there would be no need to duct fresh air from up front into the footwells.
Several companies make 12-24 VDC ELECTRIC A/C compressors. Then put the A/C in the trunk/boot. Might be worth a look-see.
See what Pete thinks?
Personally, I like the sight picture of the necktie tonneau :thumbsup:
Tim
Cottontop
I wanted to add that since I had fresh air vented footwells, I speak from experience.
The effect of having a flow of ambient air on your feet & legs FAR, FAR, outweighs the effect of having that slightly warmed air move up around your shoulders and face.
Of course, I had no hard or soft top. I had so much air coming and going all over the place that I hardly noticed the footwell air.
Tim
RAC68
Hi Ian,
Recently, I completed an article that addressed a way of supercharging the air stream of the cold air vent through the use of a speed-controlled 4” bilge blower. Although the installation is relatively hidden and produces a selectable (with the use of a DC speed controller) volume of air (up to 240CFM), it is not air conditioning.
All the best,
Ray
Keoke
Well Ian, if you use one of the modern compact compressors there is plenty of room to install one under the hood and its operation will not feel like someone is hanging on the rear bumper.--Fwiw--Keoke :cheers:
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 1
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Celtic 77 MGB Getting closer! MG 5
J Finally getting (re) started on the Bugeye Spridgets 27
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
D TR2/3/3A Getting difficult to start. Triumph 6
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
Rob Glasgow Getting Ready for Winter Austin Healey 24
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
Jim_Gruber 1/4 Elliptics- Getting the Bast__rd Apart Spridgets 22
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
RickPA Getting back in the game Austin Healey 5
D Getting hot in the car [AH3000mk3] Austin Healey 6
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
Boink Comedians in Cars Getting Coffee - SAAB Other Cars 0
Boink Comedians in Cars Getting Coffee - SPRITE turn... Spridgets 8
R TR2/3/3A Tr2 getting it back on the road Triumph 30
F How important is getting the float height correct on SU HD6 carbs? Austin Healey 3
J TR5/TR250 Hey Pat, you are getting behind Triumph 0
M Getting the wishbone with bushings back onto the frame... Spridgets 2
V Getting ready for Spring Austin Healey 6
Healey Nut This is just getting freaky !!! Austin Healey 21
